    Fixed linear paths and hinges
    3 Posts 3 Posters 482 Views 3 Watching
      jakob_2704
      Is there any plugin existing, where I can attach a linear bearing (moving in a set axis) or hinge (rotating in a set axis) to an object and optionally define limits:
      For the linear bearings: distance to left and right
      For the hinges: min/max angle
      Would make it easier to move/rotate anything in a fixed way, for example a sliding door.
        You can create Dynamic Components that would work that way.
          Does it a big deal to use or on the fly ?
          Dave will be pleased : i have only used native tools! πŸ’š
          If you want a minimum and maximum, just draw 2 help guides: so you can move your objects
          between these 2 limits! πŸ€“
