    Dimension Lines - Brackets
    2 Posts 2 Posters 412 Views 2 Watching
      djh
      Is it possible to make the straight dimension lines into brackets {} to show the space between two points in SU?
      Dimension Lines - Brackets.pdf
        Not in SketchUp. You could draw the dimension lines and brackets manually. You could modify dimensions created in LayOut to look like that although for perspective views, I think drawing the brackets in SU would be easier.
