    Legends
    1 Posts 1 Posters 350 Views 1 Watching
    • L
      Laggingbehind
      What I do is create kitchen layout drawings. Each appliance will have a unique number & a description.... a bill of quantities so to speak. ie 01 would be a st/st bench 02 would be a open top range 03 would be a st/st bench etc etc.
      What would be the best way of doing this in Sketchup Pro ot layout. Currently I use Autocad & the number is an attributed block which I then use the "data extract" command to create the legend.. The beauty of that is I can have a library of numbers which I just pull onto the drawing & edit the number bit as the description is already written. Not sure how well I explained that to be honest but hopefully someone will pick up on what I need to achieve & point me in the right direction
