    Find position of component in world space
    5 Posts 2 Posters 828 Views 2 Watching
    • C
      chanz
      There seem to be a lot of old threads about this without any great answers.
      I create a box with unit size 1, 1, 1. I put it at the origin.
      Now I make a copy of that box and move it to another point in 3d space.
      How can I find the position of that box? If that doesn't make sense given that a box is made up of different vertices, how can I find the position of those vertices? Which tool lets me see the world vertex position? What if I make it a component? How do I see the position of the component?
      These seem like simple things to do but I can't find a way. They are instrumental in level design and accuracy.
      Thank you πŸ˜„
        This is not sufficient ?
        So this point of this component is at X= -2.18 , Y = 3.12, Z = 0 for example πŸ˜„
        • C
          chanz
          That's exactly what I needed. Thanks! πŸ˜„
          I will definitely try the script, too. Thank you both.
            This can also help you πŸ˜„
            Axes Tool by Thomthom for Automatic Center Components axes!
            View axes by Menu Display / Animation/ Parameters / Components / Display Components axes
            The drawing of line is made in Edit Component!
            Idem for the Label Text!
            Mode XRay can also help! Not Used here! Just Hide Front Face! πŸ€“
              Thank you both.
              Seems I am alone! 🀒
