    Shortcut in 2016 version
    3 Posts 2 Posters 598 Views 2 Watching
    • J
      Jeremy Nicholls
      I created a shortcut (Ctrl+T) to toggle the display of the default tray. SU asked me to confirm since Ctrl+T is used by another command. The shortcut works as expected while I am using SU but it reverts to its old setting when I restart SU. I have successfully customized and/or imported shortcuts over many versions of SU in the past including 2016. Why won't it work now?
        I believe Ctrl+T is hard coded. Try a different shortcut. I use Ctrl+Shift+T and it works.
        • J
          Jeremy Nicholls
          Thanks. Will try that
