    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Foundation Plugin
    439 Posts 15 Posters 420.2k Views 15 Watching
    • medeekM Offline
      medeek
      As I've been putting the new interior footing module through its paces it occurred to me that the waffle type floor systems seen in large parking structures and in Australian residential construction will now be possible with this new feature.
      I'm pretty excited to finally see this feature become a reality. I should have made this happen a couple years ago, but in all truthfulness I probably did not possess the programming chops or experience to make it happen at the time.
      Fast forward a couple years, and I have much better handle of what I can and can't do with SketchUp's API. I've also been able to lean on and gain advice from some of the SketchUp sages along the way. Thank-you for coming to my rescue, and being so generous with your advice and time, it has made all the difference.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.3.0 - 07.14.2019
        • Added interior footings for rectangular slab-on-grade foundations.
        • Added interior footings for polygon slab-on-grade foundations.
        • Enabled editing, moving and deleting of interior footings for all slab-on-grade foundations.
        http://design.medeek.com/resources/trussplugin/images/truss_su457_800.jpg
        This is a substantial upgrade for slab-on-grade foundations. I've completely removed the old interior footing code and replaced it with the new interior footing module. The ability to add, move, edit and delete each interior footing on an unlimited basis is a breath of fresh air for this plugin.
        Now I just need to do something similar for stemwall foundations and slabs... there is always more to do.
        Later today, after a small break, I will put out a tutorial video explaining the features of this new module and demonstrate its use.
        design.medeek.com
        • jujuJ Offline
          juju
          your download page for this indicates version 1.2.3 released 07/14/2019.
          • medeekM Offline
            medeek
            Which page are you referring to? Can you give me the URL. The plugin page on my website is showing version 1.3.0.
            design.medeek.com
            • medeekM Offline
              medeek
              I've been considering the addition of a tool that adds in a depression to the slab-on-grade. The user would create any polygon shape which would then be used to generate this depressed region on the slab.
              The actual modifications to the concrete slab would be fairly easy to accomplish with the API however a number of ripple effects would pose other problems. The first problem would be slab reinforcement. The depressed region would need to have its reinforcement translated down with the slab so it remains centered within the slab.
              A similar problem exists for slab insulation and subbase material, these items would need to be moved down in the z direction as well. This of course is assuming that the slab in the depressed region remains the same thickness as the rest of the slab, however this might not be the case.
              One could assign the a zero thickness to the depressed region slab thickness which essentially cuts a hole in the slab if the depression is equal to the slab thickness.
              Or one could specify a thicker slab in this depressed region.
              Regardless slab depressions are quite interesting and introduce a number of complex problems when combined with other features like internal footings, slab insulation, subbase and slab reinforcement.
              design.medeek.com
              • medeekM Offline
                medeek
                After mauling this over a bit more I think I can deal with the concrete, slab insulation, interior footings and subbase fairly easily with a slab depression, however the slab reinforcement is a bit more challenging. Even the footing top bars are a bit problematic ( they need to be dropped as well) as one can see in the image below:
                http://design.medeek.com/resources/trussplugin/images/truss_su458_800.jpg
                At the moment I don't have a good answer for how to deal with slab depressions when combined with slab reinforcement. If anyone has a good idea I'm open to suggestion.
                This type of slab depression (4") is fairly typical for a garage that is attached to the main residence.
                View model here:
                3D Warehouse
                3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                (3dwarehouse.sketchup.com)
                I'm not saying there are not solutions to this problem but they become very computationally expensive (ie. boolean subtraction) and are not at all optimal.
                design.medeek.com
                • jujuJ Offline
                  juju
                  see attached πŸ‘
                  • medeekM Offline
                    medeek
                    A website typo, please check it now...
                    Thank-you for promptly bringing this to my attention.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 3 - Interior Footings for Slab-on-Grade Foundations (16:33 min.)
                      Interior footings for rectangular slab-on-grade foundations is identical to working with polygon shaped foundations.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        First look at the slab depression toolbar:
                        http://design.medeek.com/resources/images/foundation_dep_su_menu_active.jpg
                        This toolbar will allow the user to add, delete, edit or modify slab depressions within slab-on-grade or slab foundations.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          BUG REPORT: I'm missing a transform in the "Add Interior Footing" tool, so if a foundation is created in a location other than the origin, it may produce an unexpected result (ie. shifted footing location). I am working on the fix currently. Funny that I never exposed this error in my testing or even in the tutorial video, it does take a special set of circumstances.
                          I've also identified another issue where two footings might be coincident at their ends (start or end) at a non-orthogonal angle, see image below:
                          http://design.medeek.com/resources/trussplugin/images/truss_su459_800.jpg
                          In such a situation rather than sloping the ends of the footing towards each other I need to miter the ends so that they meet cleanly. Just some additional code in the block of code that applies the slope to the footings.
                          If three footings or more footings were to meet at a single point then the boolean union of them would work out without a hitch, it is only when you join two footings at their ends that this scenario becomes an issue.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.3.0b - 07.16.2019
                            • Added the Slab Depression toolbar and icons.
                            • Enabled a 45 deg. miter option for the ends of interior footings.
                            • Fixed a bug with the initial positioning transforms for the interior footing draw tool.
                            The option for mitering is tucked into the start and end slope option. Now in addition to the Yes/No options you also can have it miter left or right (45 deg only).
                            http://design.medeek.com/resources/trussplugin/images/truss_su460_800.jpg
                            This is a critical update since the transform bug was a significant issue with Version 1.3.0.
                            The slab depression functions/tools are still under construction and currently not functional.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Hmmm, you might be on to something with this.
                              I agree that the amount of toolbars has multiplied quite rapidly as I keep adding more features to each plugin, it does take up quite a bit of screen real estate now.
                              design.medeek.com
                              • jujuJ Offline
                                juju
                                thanks for the efforts!
                                the toolbars for your extensions are becoming rather elaborate and taking up a bit of toolbar / screen space, any chance you could implement a single initiation button/icon instead and have a secondary open when the primary has been triggered, much like Fredo does some of his extensions?
                                • medeekM Offline
                                  medeek
                                  Version 1.3.1 - 07.19.2019
                                  • Added slab depressions for rectangular and polygon slab-on-grade foundations.
                                  • Enabled editing, moving and deleting of slab depressions for all slab-on-grade foundations.
                                  • When construction callouts and subbase material is enabled, the volume of the subbase material is displayed beneath the foundation label (currently only slab-on-grade foundation assemblies have this feature available).
                                  http://design.medeek.com/resources/trussplugin/images/truss_su461_800.jpg
                                  The slab depression tool can also be used to cut thru holes into the slab, as shown.
                                  Note that additional work still needs to be done to properly modify rebar and mesh for slab depressions. Currently there is no logic in place to modify the perimeter or slab rebar when a slab depression is utilized within a slab-on-grade foundation.
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 4 - Slab Depressions for Slab-on-Grade Foundations (9:35 min.):
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Trying to take a day off from the programming but my mind keeps coming back to it and the brick ledge module (for slab-on-grade foundations) I have left unfinished.
                                      Giving it a bit of thought this afternoon and I've come up with the following parameters:
                                      • Ledge Width
                                      • Ledge Height
                                      • Start Ext.: Defaults to zero
                                      • End Ext.: Defaults to zero
                                      Really not much to it, or so it would seem.
                                      The idea is to be able to create a brick ledge on any specified edge (perimeter) of the foundation rather than around the entire foundation. A lot of modern designs only utilize a brick facade on the front of the house and not on the rear so this ability to be selective with each wall is critical.
                                      Once I have this feature up and running I think the tools afforded the slab-on-grade type of foundation will allow it to be utilized for most designs however additional work will still need to be done to make the rebar placement correct in a complex design.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at brick ledges combined with a slab depression (garage).
                                        http://design.medeek.com/resources/trussplugin/images/truss_su462_800.jpg
                                        The trickiest part of the brick ledge module was the tool that selects the foundation edge. I have it working stably now but I need to add some additional logic which prevents the user from duplicating a brick ledge along the same foundation edge.
                                        I also need to add in some additional logic which offsets the anchor bolts the appropriate amount given the width of the brick ledge.
                                        Similar to the slab depressions the brick ledge module makes no accommodations currently for rebar placement. The logic and algorithms for that will take some considerable effort.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Here is slight modification where the slab depression is lower than the brick ledge:
                                          http://design.medeek.com/resources/trussplugin/images/truss_su463_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.3.2 - 07.22.2019
                                            • Added brick ledges for rectangular and polygon slab-on-grade foundations.
                                            • Enabled editing, and deleting of brick ledges for all slab-on-grade foundations.
                                            • Added an additional layer for hidden geometry into the Layers tab of the Global Settings.
                                            design.medeek.com
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 21
                                            • 22
                                            • 12 / 22
