    Applying Material or Color to Group
    3 Posts 3 Posters 920 Views 3 Watching
    • medeekM
      medeek
      How does one apply a color or material to a group? I can't seem to find a simple explanation or example in the SketchUp API documentation.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • D
        driven
        a group is a drawing element so look at
        Drawingelement.material=
        in the API
        john
        • TIGT
          group.material=material
          Where the given material is a reference to a material already available in the model, or perhaps it's the name of an existing material, or the name of one of the standard 'color' - that might be not yet loaded:
          So e.g.
          material=Sketchup.active_model.materials['truss_wood']Where material returns 'nil' if it's not found, or a reference to that named material otherwise.
          Or alternatively:
          material='truss_wood'
          which will work if you know that the material named 'truss_wood' is already in the model,
          or perhaps...
          material='brown'
          Which uses the material named 'brown', or it makes the new material then uses it otherwise.
          There is a preset list of 'colors' [à la html]:
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/color
          If you want a material with another color or transparent, or a texture, then you must add it to the model.materials before referencing it.
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/materials#add
          You then create a new color and apply it to that new material, which by default would be black with no transparency [0,0,0,0]
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/material#color=
          If you also want to add a texture to the material, use http://www.sketchup.com/intl/en/developer/docs/ourdoc/material#texture=
          Which specifies the image file to use, then you can edit the texture's details with texture=material.texture Using:http://www.sketchup.com/intl/en/developer/docs/ourdoc/texture#size=
          etc...
