    Problem with Shake graphics
    7 Posts 4 Posters 999 Views 4 Watching
    • L
      littleche
      I have problem with Shake graphics in Column . Columns are component . if I explode all Columns,The problem will be solved ! But I need These in component figure .
      I upload movie that show Shake graphics in Column also I Upload the file .
      movie.rar
      Base (2).skp
      • HornOxxH
        HornOxx
        hi - I have no idea why your columns were flickering ❓ I don´t find anything wrong
        Anyway, I've made a new column component, uniform to yours, and replaced your columns by the new one.
        Now it works without flickering...
        Base hx.skp
        never trust a skinny cook
          Seems it's normal as Columns are intersected with Walls/Windows...
          • L
            littleche
            Hi HornOxx
            thanks for your reply . I can draw a new component like you ,but I want solve this problem . drawing a new component Not the solution its just the escape route . thanks again from you .
            Hi pilou
            It's not normal! if you watch a movei You can sure understand !
            I think its a Bug in SU .
            • BoxB
              The component axis for your column component is way of in the distance.
              Right click on one of them and Change Axes and the flickering will go away.
              The normal Z-Fighting will remain where faces try to occupy the same space.
              • L
                littleche
                Hi Box . THanks , Its solved ! 👍
                Thanks for your reply. Place of Axes is important and I forget its .
                thanks again and again . 😄
                  It's not very good to have "intersection" between objects even speedy rendering can resolve this in a fly! 😉
                  Some rendering engines are not so clement! 💚
