    Selection error?? with Ruby API
    7 Posts 5 Posters 1.5k Views 5 Watching
    • H
      hanl000
      Hi.
      I was working on 'Selection' with Ruby API and have a problem with it.
      entities=Sketchup.active_model.active_entities
      selection = Sketchup.active_model.selection
      a = entities.grep(Sketchup;;Group).each{|e|selection.add e if e.name.include?('aaa')}
      This is the code selects groups of which name has 'aaa' and it looked like all 'aaa' were selected well.
      The problem was the array 'a' contained other groups together not only 'aaa'.
      Once I tried to do next work(ex : a.hidden = true), other unnecessary groups were worked together.
      The ruby code editor said
      Done. Ruby says: [#Sketchup::Group:0x00000009e7c468, #Sketchup::Group:0x00000009e762c0, #Sketchup::Group:0x00000009e65ab0, #Sketchup::Group:0x00000009e5f868, #Sketchup::Group:0x00000009e3f040, #Sketchup::Group:0x00000009e06920, #Sketchup::Group:0x00000009e05368]
      in the array, only three things should have been selected(I put 7 objects in space. the name of 3 of 7 groups was 'aaa' and others had name of 'bbb')
      How can I exactly select only what I want?
      • D
        dezmo
        I think you were selected already what you want. πŸ˜‰
        But the "a" array is contains all groups since you were grep-ed it. Inside the iteration you have a right selection aray. You have to look for that for example like this:
        selection.each{|e| e.hidden=true}
        So the "selection" will be your array of selected groups.
        (Btw. I don't think you can apply s.hidden=true you heve to iterate through each element... )
        More simple:
        entities.grep(Sketchup;;Group).each{|e| e.hidden=true if e.name.include?('aaa')}
        Man can do everything. Only a matter of time and money.
        • TIGT
          To make minor adjustments...
          Typo in 'ents' referencing fixed, alternative [more flexible?] testing and clearing the selection before adding matches...
          ents = Sketchup.active_model.active_entities
          sel  = Sketchup.active_model.selection
          a = ents.grep(Sketchup;;Group).find_all {|e|
            e.name =~ /aaa/
          sel.clear
          sel.add(a)
          • thomthomT
            Note to add to selecting/deselecting - if you do multiple entities make sure you collected them in arrays and pass in the array to selection.add/remove. If you call .add/.remove on each entity it'll be many times slower.
            • H
              hanl000
              Thank you for all kind replies. All my problems are solved except one :
              is there a pattern which determines the order of elements in array? or are they designated randomly in array? If there is a pattern, It will be much easier to control objects
              • Dan RathbunD
                Dan Rathbun
                You need to use a filtering method. The each method always returns the entire collection object, regardless of what you do in the iteration block.
                sel.add(a)
                (Fixed: " a = ents.grep" was: " a = entities.grep"
                Array and most array-like SketchUp API collections have Ruby's Enumerable library module mixed in. So you can use any of it's methods, like find() and find_all(), etc.
                I'm not here much anymore.
                • Dan RathbunD
                  Dan Rathbun
                  No pattern. The various ways that the user can manipulate the selection set makes any order meaningless.
                  Ie: single pick, single pick + CTRL, single pick + SHIFT, Window Right-to-Left pick, Window Right-to-Left pick + CTRL, Window Right-to-Left pick + SHIFT, Window Left-to-Right pick, Window Left-to-Right pick + CTRL, and Window Left-to-Right pick + SHIFT.
                  Any of these, followed by any other number of them, in whatever order the user may use them, creates a selection set in which the pick order has no importance.
                  That said, ...
                  You question indicates you are perhaps trying to program a workflow that would better be implemented as a Ruby Tool, using a Sketchup::PickHelper.
                  Another alternative might be a Sketchup::SelectionObserver subclass.
