    Problem export dwg
    2 Posts 2 Posters 337 Views 2 Watching
    • L
      leoberastegui
      Hello,
      I have a problem when I export my skp model in DWG: all the faces are exported.
      I would like to export only the faces that appears in my view.
      I had tested all the different styles (hidden lines, shadow), nothing work..
      If any one can help thank you very much
      • S
        slbaumgartner
        Are you exporting as a 3D model or as a 2D graphic?
        SketchUp always exports all of a model when you select 3D model. To export only a part of a model, you can cut and paste the desired entities to a new model window and then export the new model.
        For a 2D graphic export, SketchUp generates essentially a snapshot of the current view. So, anything not visible on the current view will be omitted. But also the graphic will capture the as-displayed view including effects such as zoom, foreshortening and perspective, not true coordinates of points.
