    Anyone know a plugin that can produce wavy lines?
    31 Posts 8 Posters 4.2k Views 8 Watching
    • shukritobiS Offline
      shukritobi
      Does anyone knows a plugin that can do this feature:
        Bezier Splines + Curviloft by Fredo 6
        • U Offline
          unearthed
          Is there a plugin that'll do a ragged lines - I do these in vectorworks for simply graphics and it'd be cool to do them in SU, it'd also be another nail in the vectorworks coffin!
          Growplan - People ∩ Plants ∩ Place
          windows 7 64b, 4GB RAM, SU 8.0.16846
          Gimp, QGIS, Vectorworks 12, Bricscad 11
            ragged lines
            Eneroth Fractal Terrain Eroder | SketchUcation
            (sketchucation.com)
              driven
              to do this sort of thing?
              click to see gif...
              john
              • pbacotP Offline
                I don't see it as much a question of having a cool parametric way of making the wavy pattern than of applying that to your geometry cleanly, as driven has. I don't think there's a tool as slick in the SU plugins as the one you show in the video, but I'd start by making a portion of the curve and have that portion be sized to surround the vessel in an even number of sections and align to the vertical divisions.
                I haven't begun to use myself but I suspect Subd would be a good one to model this with.
                  driven
                  not sure if the OP will return, but I made that with a plugin I adapted...
                  so far it only makes a welded sinusoidal circle, that you can set the segments, height and frequency of...
                  by moving and scaling copies, you can replicate the results in the video...
                  just takes a bit longer...
                  john
                    Very nice, John.
                    • pbacotP Offline
                      Impressive coding, driven-- John!
                        driven
                        it's coming along, I'll send you both a demo version...
                        the gifs a bit rough...
                        Dave can try some intricate wood turning...
                        john
                        • soloS Offline
                          solo
                          Error Loading File C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle/sine_circle_logic.rb
                          Error; #<NameError; undefined local variable or method `__File__' for main;Object>
                          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle/sine_circle_logic.rb;113;in `<top (required)>'
                          C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in `require'
                          C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in `load'
                          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle.rb;35;in `register_extension'
                          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle.rb;35;in `<module;SineCircle>'
                          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle.rb;10;in `<module;JcB>'
                          C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jcb_sine_circle.rb;8;in `<top (required)>'
                          http://www.solos-art.com
                            driven
                            cheers Pete, I chucked that in at the last minute incase 'someone' wanted to test it on SUv6, I'll revert to what was working >>> give me a minute...
                            john
                              It works on my PC with SU2016 but the toolbar button icon isn't very original. πŸ˜„
                                driven
                                @ Dave you had the pre v6 mod, which was just a typo, but it also has the 'PC' png icon instead of the pdf mac one I started with...
                                @Pete I updated the rbz...
                                john
                                  New version seems to be just fine for me and there's now a nice toolbar button icon. πŸ‘ πŸ‘
                                    driven
                                    cheers Dave, how did you make that?
                                    I did some with just this and moving grouped copies, exploding, but did you use a second plugin for the surfaces?
                                    john
                                      John, I made two sine waves, connected them with lines and then used TIG's Extrude Edges by Rails to create a surface. Then Joint P/P for thickness.
                                        driven
                                        like this...
                                        the gifs a bit odd...
                                        john
                                          That's definitely another way to do it. πŸ˜„
                                          • JQLJ Offline
                                            JQL
                                            Sometimes, out of nowhere, you guys pull off this kind of stunts!
                                            Amazing work on the plugin John, amazing simplicity of processes with the scale tool too. Nice simple idea from Dave. Congratulations on a very nice thread!
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 1 / 2
