Error installing distribute_objects_tools_v1.0.0
Hi i have download and install distribute_objects_tools_v1.0.0 and restart the sketchup Im getting the error plugin expire (3 files attached). I have installed 1st time and not yet used once also how it expire.
An easy search on your part would have turned up the following: http://sketchucation.com/pluginstore?pauthor=cesaro36
Contact the author at the link given in the error messages. Apparently the author set a time limit on the free trial. That trial period has ended so unless the author establishes a new trial, you'll have to buy the extensions if you want to use them.
Register LoginAdvertisement
