    [IDEA] Skatter + MS physics ?
    8 Posts 5 Posters 1.3k Views 5 Watching
      MrWip
      Hi all,
      I just came across this 3ds max plugin : PhysX Painter
      It's a really interesting tool, based on an object painter and a simple rigid body engine.
      I was wondering if something like that seems to be possible in sketchup, maybe an half breed between Skatter and MS physics.. 😄
      What do you think ?
      http://www.wip-archi.com
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        You can do just that 😄
        Use Skatter to place the objects, then use SP/MSPhysics on the generated objects.
          MrWip
          Well, you're right Jiminy, it works !
          I did a quick test with leaves found on the warehouse, a basic ground surface, and a quick Skatter setup. It's efficient on the skatter side, but take long (about 5min on a good configuration), to calculate the physic part. Maybe there are way to improve that, I'm not an MSphysics expert...
          Before the physic drop
          SKATTER PHYSICS.skp
          And after !
          SKATTER PHYSICS bis.skp
            jiminy-billy-bob
            • F Offline
              faust07
              Great experiment! Select all leaves and define their bodies as a box, then the simulation is faster. Playing with different materials is fun. Now you just need a little wind.
              • F Offline
                faust07
                And here your leaves with a little wind.
                full length & higher resolution
                • JQLJ Offline
                  JQL
                  Cool guys!
                  www.casca.pt
                  Visit us on facebook!
                    And seems replace random components by Sdmitch can make some tricks shown on the video! 😉
