Force sketchup ctrl+s/autosave to sketchup 8?
Hi, I am experimenting with linking grasshopper to sketchup (I have found a plugin in which ctrl+s in sketchup automatically imports it to grasshopper with updated version), and I need to have sketchup 8 file all the time. I would like to work in newer sketchup program though to have access to many plugins.
I did not find any option to force this on sketchup,
any help?
you would probably have better luck with replies if you post this in the developer section of the forum
thank you I will do this
@mazurek said:
...I did not find any option to force this on sketchup...
you can't over-ride System commands, you need a plugin to save as different version and use a different shortcut key.
have you looked at this one... http://sketchucation.com/forums/viewtopic.php?p=294768#p294768
john
Register LoginAdvertisement
