    Force sketchup ctrl+s/autosave to sketchup 8?
    4 Posts 3 Posters 397 Views 3 Watching
      mazurek
      Hi, I am experimenting with linking grasshopper to sketchup (I have found a plugin in which ctrl+s in sketchup automatically imports it to grasshopper with updated version), and I need to have sketchup 8 file all the time. I would like to work in newer sketchup program though to have access to many plugins.
      I did not find any option to force this on sketchup,
      any help? ❓
      • jujuJ Offline
        juju
        you would probably have better luck with replies if you post this in the developer section of the forum
          mazurek
          thank you I will do this
            driven
            @mazurek said:
            ...I did not find any option to force this on sketchup...
            you can't over-ride System commands, you need a plugin to save as different version and use a different shortcut key.
            have you looked at this one... http://sketchucation.com/forums/viewtopic.php?p=294768#p294768
