    Extension creation code
    2 Posts 2 Posters 578 Views 2 Watching
    • S
      sonjachr
      I have the following problem with the extension installation in Sketchup 2016:
      I use the following code to load my plugin:
      ` # Load the normal support files.
      require 'sketchup.rb'
      require 'extensions.rb'
      Create the extension.
      ext = SketchupExtension.new('pluginName', File.join('pluginFolder', 'pluginLoader.rb'))
      Attach some nice info.
      ext.creator = 'xxxxx'
      ext.version = '1.0.0'
      ext.copyright = '2016, xxxxxxxx'
      ext.description = 'xxxxxxxxxxxxxxxxxxx'
      ext.extension_path=File.join(File.dirname(FILE), "pluginFolder" )
      Register and load the extension on startup.
      Sketchup.register_extension(ext, true)`
      The Preferences/Extension Window then shows 2 entries for my plugin, one with the name of the pluginFolder and one with the pluginName. Only the entry with the pluginName shows also the plugin details.
      When I delete the ext.extension_path entry in the above code, everything seems to be OK.
      As I use the ext.extension_path in my loader file I need to fix this problem, which did not occur in previous Sketchup Versions.
      Help is very much appreciated
      • TIGT
        You have omitted some code and added in other unneeded code.
        Try:
        # Optionally 'name' the Extension - it can differ from the registered name.
        ext.name = 'pluginName'
        # This 'path' is NOT needed.
        Add in the bold code and remove the struck-through code...
