    Import dwg-file
    5 Posts 3 Posters 973 Views 3 Watching
    • V Offline
      vigge50
      Hello
      I have now I little problem, for some days ago I imported a dwg-file I had got to use for a 3D-model on my dads computer. Everything work fine with importing the file but now then I got a new file and is home with my own computer I can't import dwg-files. I go to file>import but I can't chose dwg-files. Anyone who know how I can fix it?
      • pbacotP Offline
        Did you check in the open dialog that the pulldown menu at the bottom shows "AutoCAD Files (.dwg,.dxf)"?
        • V Offline
          vigge50
          I can't find it, sorry for bad image
          • V Offline
            vigge50
            Does anyone know how to solve it?
              I think was solved for you on the other forum. You appear to be running SketchUp Make instead of SketchUp Pro
