    Newb SubD question, exclude a face from process?
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    4 Posts 2 Posters 8.1k Views 2 Watching
      S Shepherd
      Sorry if this is painfully obvious but I'm wondering if it is or will be possible to exclude a face from the SubD process. For example, if I wanted to connect a subD object to a square (for instance) model without having to produce a transition. In the pic I'd like to subd the green but not the red.
      I hope this makes sense.
      Great Plugin BTW I think I'll be popping on this when I get a paypal account straightened out.
      Shep
      • BoxB Offline
        Shep you can use the crease tool for that.
          S Shepherd
          Thanks Box, that looks great.
          Shep
          • BoxB Offline
            Just be aware shep that the actual corner vertices can be creased as well as the edges. You'll get different results if you don't do the corners. If you notice in the gif when I select the crease tool the corners are already red. meaning I have creased them before recording.
