    Thomthom, can you help me ?
    7 Posts 4 Posters 1.3k Views 4 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Anyone encountered the same problem as me ? Just do the following:
      Create a simple class:
      class Test
      	attr_accessor ;model
      	def initialize()
      		@model = Sketchup.active_model
      Instanciate an object of that class:
      obj=WebGLExporter;;Test.new()
      Look at this object:
      obj.inspect
      Here's what I get: ๐Ÿ˜ฎ
      #<WebGLExporter::Test:0x19dbaa18 @model=#<Sketchup::Model:0xe272680 @tt_bezier_surface_editor=#TT::Plugins::BezierSurfaceTools::BezierSurfaceEditor:0x139ef300>>
      Thomthom, I have your Bezier surface plugin installed, along with TT_Lib2 of course.
      What do you think ??
      DB
      • TIGT
        Using a bald 'Test' Class is asking for problems...
        I think thomthom's older [unsupported] files can get convoluted...
        Try wrapping it in your own module...
        module DidierBur
         module WebGLExporter
          class Test
            def initialize()
        Then use:
        obj = DidierBur;;WebGLExporter;;Test.new()
        obj.inspect
        Works for me:
        #<DidierBur::WebGLExporter::Test:0x0000001527eec0 @model=#<Sketchup::Model:0x000000127edd00>>
        • thomthomT
          This is probably related to something I tried a long time ago with BezierSurface. I was trying to keep a map of SketchUp model to a BezierSurface::Editor instance. (https://bitbucket.org/thomthom/bezier-surface/src/9f9a8d9a0634b4502779a6add502d424904f1364/src/tt_bezier_surface/core.rb?at=default%26amp;fileviewer=file-view-default#core.rb-160) At that time I thought the model reference I would get was unique to me, so I attached an instance variable to the model object itself. Back then we had Ruby 1.8 and it didn't display instance variables when you did an inspect.
          However, I later learned that SU reuse Model and Entity instances - meaning that we all share the same Ruby object. But that was after I stopped maintaining BezierSurface and I'd completely forgotten about it.
          Ruby 2.0's version inspect changed such that it display the content of instance variables - making this more apparent. So your Test class is printing the @model instance variable which in turns has my bezier surface instance variable.
          Sorry about the noise. I'll add a ticket to try to refactor that.
          Meanwhile, if you want to customize how your Test class in inspected you can do something like this to return to original Ruby 1.8 behaviour: (https://github.com/thomthom/SKUI/blob/master/src/SKUI/base.rb#L104)
          class MyClass
            def object_id_hex
                "0x%x" % ( object_id << 1 )
          • thomthomT
            Test is a module in the StdLib. If it's not loaded the Ruby core won't have defined it.
            • Dan RathbunD
              Dan Rathbun
              true !
              Ref: http://ruby-doc.org/stdlib-2.0.0/libdoc/test/unit/rdoc/Test.html
              Not quite correct.
              Since the SketchUp API Core adds methods to the Test module, it will always be defined.
              Test.methods(false).sort %(#000000)[>> [:AutoClickTime, :AutoClickTime=, :AutoDragDistance, :AutoDragDistance=, :CorruptModel, :FindFile, :diff, :eat_mem, :export_animation, :flip_images_for_origami, :project_textures_from_photo, :repair_model, :show_fps, :suppress_warnings=, :suppress_warnings?, :time_display, :time_pick, :use_sg_off_screen, :use_sg_on_screen]]
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                You can't. Test is a pre-defined Ruby standard module at the toplevel. (Edit: It's actually a library module, as Thomas points out below. But it's always defined, I will counter.)
                Test.class %(#000000)[>> Module]
                class Test; def what(); puts "testing...": end; end %(#000000)[>> Error: #<TypeError: Test is not a class>]
                • thomthomT
                  Yes, unfortunately SU added a Test module for internal testing methods a long time back - before we included StdLib. ๐Ÿ˜ž
