    Bird back to start
    16 Posts 8 Posters 12.4k Views 8 Watching
    • F
      faust07
      I need help to bring the bird back to the beginning of the curve, and then to let him fly in an infinite loop. The script is in the body of the bird. Thanks in advance!
      BirdTest01k_01.avi
      BirdTest01SUF.skp
      • soloS
        solo
        I have no idea, however I'm impressed with the video of what you have achieved, the camera is also well done on how it tracks the bird.
        http://www.solos-art.com
        • ntxdaveN
          ntxdave
          Really cool........does SketchyPhysics allow you to define a path?
          I assume not or you would already have it in the animation. The motion is very smooth (both the bird and the camera). Well Done...... ๐Ÿ‘ ๐Ÿ‘
          Press F1...thank me later
            Why not have a closed curve? Or with a very tiny gap?
            Or with the gap = last segment = first segment
            • F
              faust07
              Thanks, Solo & ntxdave! I'm trying to evolve existing SP models and scripts and to use them for animation. There are a lot of insanely good examples in the Forum and in the warehouse such as path following scripts. Since SketchyPhysics is running very stable for a while (thanks to Anton_S and PituPhysics), it makes fun to experiment with it again. A small intermediate goal is, to send objects such as vehicles, walking people, birds, airplanes, ships etc into short continuous loops ... Unfortunately, my Ruby programming skills are still rudimentary.
              @ Pilou: Yes, closed curves and small gaps would be good too. In the script a program loop should be built in with the meaning of - "if objekt is at the end of the path, start again at the beginning". Sounds simple, but I'm not able to write this ...
              • ntxdaveN
                ntxdave
                @Fredo6 is this something that could be done with the upcoming Animator?
                • A
                  Anton_S
                  Very nice birdy, faust07.
                  Here is the code to make the birdy loop on the desired curve.
                  setLinearDamping(5.0)
                  onstart {
                    curve_verts = $curPhysicsSimulation.findCurve("path01")
                    @curve_length = $curPhysicsSimulation.getCurveLength(curve_verts)
                  ontick{
                     lookAt(evalCurveAbs("path01", (frame * 8) % @curve_length + 180))
                     dir = position.vector_to(evalCurveAbs("path01", (frame * 8) % @curve_length))
                     dir.length = dir.length / 12.0
                     push(dir.to_a)
                  Of course, the main curve isn't quite "loopable", so the transitioning from the last point to the starting point won't be quite realistic until the curve is modified to be "loopable".
                    It's a code for SketchyPhysics or MsPhysics ?
                    Does it possible also in MSPhysics ?
                    • A
                      Anton_S
                      The code is for SketchyPhysics (as the birdy was made for SP). Copy and paste it into the body of the bird into the script field.
                      Yes, everything done in SketchyPhysics can be tweaked to work in MSPhysics. (The code would look different however as the scripting functions differ in SketchyPhysics and MSPhysics.)
                      • F
                        faust07
                        Thank you very much, Anton! Works like a charme: ๐Ÿ‘
                        And the script supplement looks so easy. Nevertheless, I still need some time to understand it.
                        Endless flying birds in the sky are no longer a problem...
                        BirdTest01k_02k.avi
                        • HornOxxH
                          HornOxx
                          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                          this whole "SP-thing" is a miracle to me and with big eyes I am so amazed like a child ๐Ÿ˜ฎ
                          It's great to see the birdยดs flight, itยดs movements just like the perfect camera tracking.
                          When I myself am glad that any cube falls right down onto the ground, the here shown
                          SP-level is enchanting.
                          just great!
                          never trust a skinny cook
                          • ntxdaveN
                            ntxdave
                            Well done @faust07 ๐Ÿ‘ ๐Ÿ‘
                            Nice and smooth and the movement of the wings looks very realistic.
                            • F
                              faust07
                              Thanks again for the kind words guys. Here a little more bird action ... Everything is normal SketchUp output. The possibilities for designing camera movements with SketchyPhysics are unlimited. Thats great! The bird is flying in Antons loop. The camera is controlled by the SUp scenes.
                              Hi Chri. Telepathy ... Unfortunately, I can only animate one bird. To copy Physics objects is very time consuming. But nothing is perfect...
                              BirdTest08K3.avi
                              • chriC
                                chri
                                Hi faust
                                Incredible Job !
                                Before I saw this, I did not think we could do this , with SKETCHUP.
                                Thanks for sharing
                                Chri
                                • F
                                  faust07
                                  Benchmark for Sketchy Physics...
                                  2 birds and a bit emitter fun
                                  • pbacotP
                                    Haha. Talk about rampant development!
