How to push/pull angled surface
Hi all,
I'm creating a design for 3D printing and i have a roof which has hexagonal surfaces as you can see in the images. What i want to do is pull the surfaces in order to give them thickness for 3D printing, however, due to the angles of the surfaces, when i do pull the surfaces, they do not join and i get something like the second and third images with gaps in between.
The only thing i can think of is a line in the center at a particular length and join the edges to that line, however, i don't want to do that because its too manual and i don't know what angle to draw that line at so i'm hoping there's an easier way.
Any ideas would be appreciated.
Fredo6s JointPushPull should do this...
Thankyou so much. That did exactly what i wanted it to.
Register LoginAdvertisement
