    Styles > Edit > Color > "All same" won't keep its settings
    5 Posts 3 Posters 621 Views 3 Watching
    • D
      davedhall
      Hi there! I am new to your forum and I am using Sketchup 2016 Pro and had this exact problem with 2015 Pro version. The problem is when I add color to a grouped object the black edge outline disappears making the detail difficult to see. I have spent over half a day total trying to resolve this. The black lines show up fine when the "All same" is selected. I then save the Style and it still retains the black edge and looks fine. If I wait for the Autosave feature to save the room or if I select it manually, the Color reverts back to "By material" every time and the edges disappear again. Do you have any idea how I could fix this?
      Thank you!!
        Could you share an example file that does this?
        • BoxB
          You could try the one in this thread Dave.
          http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=63984
            Didn't realize it was the same file. I thought we'd been through this.
            If it isn't solved, I'd suggest there's either a problem with the save location of maybe something corrupt in the installation and reinstalling SketchUp might be the key.
            • D
              davedhall
              Thanks for taking the time to reply. Unfortunately that thread is from me from last week too πŸ˜„ I couldn't get the 2015 program to work even after trying everyones suggestions. I finally got the 2016 Pro and it worked fine for 3 days and then started doing the same thing. I'm sure its just a simple setting or button that has been activated in error but I can't find it...
