    Ctrl-Z (Undo) Problem
    6 Posts 3 Posters 2.2k Views 3 Watching
    • ntxdaveN
      ntxdave
      I have suddenly started getting a kind of weird result if I do multiple Ctrl-Z (Undo). I get a strange rectangle at the base point of the model (see the image below). This is happening in both 2015 Pro & 2016 Pro.
      Notice the rectangle lower right
      Am I doing something wrong (other than making silly mistakes while drawing 😐 )?
      Press F1...thank me later
      • jujuJ
        juju
        that's an undocumented feature, there to help you start the geometry on the next component
        ^^^^ sarcasm dripping from the lips
        • ely862meE
          ely862me
          If I am not wrong, this was/is the fault of a plugin. Try disabling your plugins and see if it still happens.
          Elisei (sketchupper)
          Come and See EliseiDesign
          • ntxdaveN
            ntxdave
            Last night, when I could not sleep, I was thinking something like that as well. I need to go experiment with various plugins and see if I can identify it.
            • ely862meE
              ely862me
              The SCF plugin store would help you with them, I believe. If not there is a Ruby line that disables them all.
              • ntxdaveN
                ntxdave
                Not 100% sure yet but it appears that it may be the Extrude Tools extension. I can reproduce it every time I use that extension.
