    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Offset multiple lines
    9 Posts 4 Posters 2.6k Views 4 Watching
      Citelum
      Hello
      I'm using SketchUp Pro 2016
      Does anyone know of a plug-in that can offset multiple "lines"? I have a need to be able to offset the centre line DXF drawings of a road network to create 3D images of an area.
      I've hunted for such a plug-in but can only find "multiple face offset" which won't look at the lines.
      Using the standard offset tool I have to select a whole line along its length and then offset it, say, 7 metres to one side and then 7 metres to the other side. I then have to do the same to all the other roads and then tidy up the the cross-overs (intersections).
      If I could just have the basic offset on both sides of the road lines it would make the task very quick even if I have to tidy up all of the crossovers (intersections)myself.
      I have attached a sample image to show what I'm trying to do.
      In anticipation,
      Garth
      Sample road network and offset of same
        Chris Fullmer's Greeble extension could do it. Draw a temporary face around the outside borders of your lines. Set Max and Min heights to 0 and Max and Min offsets to half the street width with a negative value. Erase what you don't need.
          CityGen Street Generator by Thomthom can maybe help you! πŸ˜‰
          http://sketchucation.com/forums/download/file.php?id=28088&t=1
            Else Protrude by Jim Foltz?
            Click image for animation!
            Protrude is very funny like the Greeble by Chris Fullmer! πŸ‘
            Here Protrude
            http://sketchucation.com/forums/download/file.php?id=29782
              Citelum
              Thanks for the suggestions. I will try them out. The CityGen plugin looks great but I don't see updates since 2009. I wonder if the plugin will work with 2016.
                Not sure
                see this link and posts following! πŸ˜‰
                I installed it in 2016 and obtain same messages!
                Waiting the Thomthom advices! πŸ˜„
                  dtrarch
                  Hi All
                  I use Tig's Extrusion Tools/Extrude Edges by Offset.
                  Never could find anything better for curves and such.
                  Just create a path/select and enter the +/- distance for offset from centerline (two operations)
                  Plan B
                  Use TIG's Extrude Along Path
                  Width = Central(plan)
                  set very small Height and flatten.
                  You will have offset edges and center line to play with.
                  The End 😎
                  dtr
                    Citelum
                    Thom Thom's CityGen is exactly what I'm looking for but how do we get it to work?
                    What vers of SketchuUp will run the plugin and is there a link to the plugin(s) that are needed?
                    Is there a guide to getting the plugin(s) up and working?
                    Garth
                      Sems remember that V8 works with any problem with it! πŸ˜‰
