    Mirrored groups/components -> make unique
    3 Posts 2 Posters 500 Views 2 Watching
      bsfranza
      hi there,
      is there a ruby script or plugin which "fixes" mirrored groups/components?
      why? we give our models to people working in max - import is fine and even instances come in pretty nice - only problem we encountered is that components which got mirrored are bad in max - because of inverted normals in some rare situatons and negative values in the scale dialog / x-form ....
      this can be handled inside of max but it would be nice if i could provide a sober solution out of sketchup...
      so a solution would be handy that finds mirrored objects with negative values and makes them unique and resets scale to positive 1x1x1 ... iterateing throuth nested componetns and so on...
      also i now that probably its not that easy with nested stuff if the outside container is positive and somewhere in level xx of the nested geometry there is the mirrored object...
      πŸ˜ƒ
      i hope someone understands and can help me with the problem or provide another workflow or tipp to overcome this issue
      thanks and have a nice year 2016
        It hardly needs a plugin.
        You could run something like this one-liner [then do the export - but because you lose any component instancing [everything becomes unique], you might NOT want to save the SKP afterwards, without an undo or two to get those instances back?]
        m=Sketchup.active_model;m.start_operation('!');m.definitions.each{|d|next if d.image?;d.instances.each{|i|i.make_unique}};m.commit_operation
        If you have any Ruby skills you could perhaps adjust it, to do the export and then do a ;model.abort_operation to undo the changes, but keep the exported file...
          bsfranza
          thanks for the help - i will try to get my hands on ruby as soon as possible! there is no way around it any longer πŸ˜ƒ
