    Making a surface into a solid, help
    4 Posts 3 Posters 7.6k Views 3 Watching
    • K Offline
      kellenraidfractal
      I have designed a curette; this is s surgical "spoon" used to scoop out soft tissue. The design of the business end is like an egg cut down the middle. I can easily add a handle, but the whole thing is just a surface.
      Here is my question: how do I make this a solid so that I can print it? I tried copying and moving it a millimeter, but then to solidify (?) it, I had to draw a whole bunch of lines. If there is an easier way, I really need to know.
        driven
        start here http://sketchucation.com/forums/viewtopic.php?p=546771#p546771
        read the whole thread and have a look at the skp file...
        john
          Generally Push Pull Interactive by Fredo6 πŸ˜‰
          • K Offline
            kellenraidfractal
            I got tgi3d and joint push pull. Together they worked well. Thank you for your help.
