    Can not make yellow triangle go away
    layout
    2 Posts 2 Posters 1.2k Views 2 Watching
    • O
      Obleyo
      Well I have had some problems.
      I saved my work in LO and left for a few hours. When I came back to it, parts of my drawings on different layers were moved or missing and the yellow triangle appeared on several pages. Leader arrows from text were now pointing off the page as though my image had somehow moved. I hadn't moved anything.
      I tried to restore to an earlier saved point from yesterday and that did not work.
      So I am redoing much of my work, but even after rendering images, the yellow triangle will not go away. I tried changing the drawings to raster and then rendering them and then back to hybrid or vector and re-rendering and that has not helped.
      So any ideas out there would be greatly appreciated.
      Thanks,
      Joel
      • S
        sonder
        Have you saved scenes in the SU model? Those scenes should be selected to render in LO in the Sketchup Model tray. If the scene in the LO Sketchup model tray reads "Last saved Sketchup view" then that is your problem. It is very important that the link to the saved scenes in SU is maintained. If you do this, the LO viewport will not shift and you will have no yellow triangles. There is no need to redo any LO work if this accidently happens - leaders and dimensions are snapping to the SU model reference. Once it is rerendered to the original scene (assuming you placed all the leaders and dimensions with the correct scene selected), everything will automatically return in order.
