    Another solid-making problem
    4 Posts 4 Posters 7.5k Views 4 Watching
    • K
      kellenraidfractal
      I am having another problem creating a solid. I have added below two concave surfaces that I offset. I am out of ideas how to make this solid. Hellllpppp!
      Two plate for solid example.skp
      • cottyC
        cotty
        One example with Curviloft (Fredo6).
        (The sides are not coplanar, should they?)
        Two plate for solid example_b.skp
        my SketchUp gallery
          From the 3 Arcs only the arc top one is coplanar! ๐Ÿ˜ฎ
          So a creepy surface! It's a bad part of cheese! ๐Ÿ’š
          No clean rotation possible, no easy past etc...
          • pbacotP
            You could "stitch" this together rather quickly. Or you could add verticals at the 3 corners then skin each of the three sides with Curviloft. Group all and reverse the faces so that all outsides are the front or white material.
            The way this was created, you could also use Extrusion tools- extrude edges by vector from one shell shape to the other (which seems to be a copy). Similarly you could have used Joint Push Pull--Vector Push Pull on one shape to extrude it up and make the second shell as well.
            One way to stitch it is just with vertical lines point to point since the shapes are identical.
