    Change Line types in an other?
    4 Posts 3 Posters 544 Views 3 Watching
    • deaneauD
      deaneau
      Hello Devs.
      Rich O'Brien have had written the Pentools+
      some Type of Lines i can view in other 3d Software.
      the Weld Line i can see in Cinema4d as a spline named One Edge Curve.
      is it possible to change the line types in an other?
      for example: i have draw a line with Hide Draw and i would have this as Guide Draw
      i have a Guide Draw and now i would have a Weld Draw
      etc.
      for an easy work flow this would be good to have a palette exactly like Pentools+ however now the function: i select a line and than i click an icon to change to (the same order of the icons would be good, too.
      the icons could look like this with the red arrow as overlay (combination).
      %(#BF0000)[can i change the measures to an other line type,too?
      and can i do this with points?]
      Edit: a ruby line for the console could be an alternative,too
      thank you Dean
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
        Maybe Color Edges by C Plassais
        Edge / Construction Lines Converters? by Michael V
          You a free to make any changes you want. I don't have the time to look at this at the moment.
          • deaneauD
            deaneau
            @ pilou ok this could be possible. ill try this
            @rich yes i understand
            thanks for yours fast answers.
            Dean
            @pilou **bingo**Color Edge is a solution.
            works in 2016,too
            thanks
