    [Plugin] [$] S4U Divide
    19 Posts 10 Posters 14.2k Views 10 Watching
    • hdpvH Offline
      hdpv
      S4u Divide v3.1.0
      Divide Faces or Surfaces follows 2 directions
      -Turn on/off Divide xaxis.
      -Divide random.
      S4u Divide v1.2.0
      -Add French by Pilou
      Divide faces follow 2 directions.
      Shortcuts key:
      • Tab : Toggle X axis ,Y axis
      • Ctrl+Click (on Win) OR Alt+Click (on Mac) : Set Origin
      • Double Click : Reverse Axis
      • After select Match Grid menu:
        Ctrl+Click (on Win) OR Alt+Click (on Mac) : Select Source Grid
        Click : Select Destination Grid
        Trial and Purchase:
        http://extensions.sketchup.com/en/content/s4u-divide
        Or:
        http://sketchucation.com/pluginstore?pln=s4u_divide
      Suforyou
      http://www.sketchupforyou.com
      • P Offline
        pejmantayebi
        hello hdpv ...
        it is not compatible with 2015 !!!
        I just 2015 pro , I tried to copy its files from 2016(make) to pro ... but there were some errors about RBE file ... I could not understand what does it mean ...
        Just a simple request : please Make it compatible with 2015 ... ( or elder versions if possible )
        Please !! 😐
        thanks a lot for your awesome tools ...
        best regards
        • sicksickisckS Offline
          sicksickisck
          OSOM
            French Language! πŸ˜„
            Rename it as your convenience! πŸ€“
            en-US.zip
            • hdpvH Offline
              hdpv
              Merci Pilou!
              Suforyou
                cuttingedge
                great useful plugin to speed things up
                • hdpvH Offline
                  hdpv
                  @pejmantayebi said:
                  hello hdpv ...
                  Please !! 😐
                  best regards
                  It's support 2014 and later,now.
                  Suforyou
                  • olisheaO Offline
                    olishea
                    how does it look on a sphere? or a torus?
                    oli
                      Why not? β˜€
                      It's strictly the same!
                      Faces are only more small so reduct the sizes! (Right Click/ Context Menu)
                      • hdpvH Offline
                        hdpv
                        now,it's not support sphere and torus automatic.
                        You are just modifier by manual.
                        Suforyou
                          Macho3001
                          Hi HD!
                          Great plugin, I have purchased it. Though it would have been brilliant if it could work on organic lofted surfaces as a single face (not multiple faces), so that panelization could be done. It would then be used in conjunction with edges to tubes and joint push pull plugins for generating building skins and facades, and models could be imported into Revit for construction drawings. Is it possible?
                          Great plugin !! No doubt.
                          Ar. Nitin Sharma
                          3DADS
                          'Leadership, by Design'
                          3rd Dimension, Architecture Design Studio
                          • hdpvH Offline
                            hdpv
                            Thank Nitin Sharma!
                            I also want Divide can work on Surface(mesh,sphere,cylinder...)
                            I think about Revit's divide tool but it's complex.
                            Maybe I will add a function for surface(1 direction) as a single face.
                            Cheers
                            VΔ©
                            Suforyou
                              bsfranza
                              if you make it working with surfaces - even limited in one direction or something like that - that would be super πŸ˜ƒ !!!
                                rv1974
                                is it possible to add random mode (with user defined min\max values)?
                                • hdpvH Offline
                                  hdpv
                                  I updated the random divide.
                                  Suforyou
                                    rv1974
                                    I unsuccessfully tried this new random mode. I couldn't get truly random gaps, all of them were exactly of min or max value (no floating values between min-max). Do I miss something or it's a current state?
                                    P.S. I attached some print screen of some 3ds max script which depicts the basic idea
                                    current state
                                    desired
                                    • hdpvH Offline
                                      hdpv
                                      Now,It is random from 1 space to 3 spaces.
                                      Maybe,I add input : "min-max" for set min and max space.
                                      Suforyou
                                      • N Offline
                                        noldo
                                        Hi hdpv, i have recently purchased your plug-in.
                                        Amazing!
                                        But when (for example) i divide a rectangle into numerous small part (in every direction, x, y), the resulting small face have some error (bad polygon flow, miss polygon).
                                        I think the cause is due to the application of the grid in both directions at the same time.
                                        Perhaps the solution is to apply, in the algorithm, first the divisions in one direction, then the divisions in the other direction.
                                        Thanks for your work!
                                        • hdpvH Offline
                                          hdpv
                                          Thanks,
                                          I will try it.
                                          Suforyou
