    [Plugin] [$] S4U Divide
    19 Posts 10 Posters 14.6k Views 10 Watching
      Why not? โ˜€
      It's strictly the same!
      Faces are only more small so reduct the sizes! (Right Click/ Context Menu)
      • hdpvH
        hdpv
        now,it's not support sphere and torus automatic.
        You are just modifier by manual.
        Suforyou
        http://www.sketchupforyou.com
          Macho3001
          Hi HD!
          Great plugin, I have purchased it. Though it would have been brilliant if it could work on organic lofted surfaces as a single face (not multiple faces), so that panelization could be done. It would then be used in conjunction with edges to tubes and joint push pull plugins for generating building skins and facades, and models could be imported into Revit for construction drawings. Is it possible?
          Great plugin !! No doubt.
          Ar. Nitin Sharma
          3DADS
          'Leadership, by Design'
          3rd Dimension, Architecture Design Studio
          • hdpvH
            hdpv
            Thank Nitin Sharma!
            I also want Divide can work on Surface(mesh,sphere,cylinder...)
            I think about Revit's divide tool but it's complex.
            Maybe I will add a function for surface(1 direction) as a single face.
            Cheers
            Vฤฉ
            Suforyou
            • B
              bsfranza
              if you make it working with surfaces - even limited in one direction or something like that - that would be super ๐Ÿ˜ƒ !!!
                rv1974
                is it possible to add random mode (with user defined min\max values)?
                • hdpvH
                  hdpv
                  I updated the random divide.
                  Suforyou
                    rv1974
                    I unsuccessfully tried this new random mode. I couldn't get truly random gaps, all of them were exactly of min or max value (no floating values between min-max). Do I miss something or it's a current state?
                    P.S. I attached some print screen of some 3ds max script which depicts the basic idea
                    current state
                    desired
                    • hdpvH
                      hdpv
                      Now,It is random from 1 space to 3 spaces.
                      Maybe,I add input : "min-max" for set min and max space.
                      Suforyou
                      • N
                        noldo
                        Hi hdpv, i have recently purchased your plug-in.
                        Amazing!
                        But when (for example) i divide a rectangle into numerous small part (in every direction, x, y), the resulting small face have some error (bad polygon flow, miss polygon).
                        I think the cause is due to the application of the grid in both directions at the same time.
                        Perhaps the solution is to apply, in the algorithm, first the divisions in one direction, then the divisions in the other direction.
                        Thanks for your work!
                        • hdpvH
                          hdpv
                          Thanks,
                          I will try it.
                          Suforyou
