    [Plugin] Mesh Importer
    32 Posts 6 Posters 7.3k Views 6 Watching
      smicha
      @jim said:
      It would help if you could try to import the file while the Ruby Console window is open, and then post any errors here.
      Mesh Importer Result:
      D:...\stone.obj.skp was not created.
        Jim
        Thanks for your patience. I just want to make sure you gave tried version 15.4 which I uploaded last evening and which fixed a similar problem kaas had?
          smicha
          Yes - the newest version. Feel free to ask more questions. I'd be glad to see the plugin working. For now I stick with TIG's obj importer.
            smicha
            BTW it seems that a cmd window blinks for a fraction of a second and does nothing.
              driven
              smicha, will it make one if the original is on your desktop?
                smicha
                It's not working at all.
                  Jim
                  Two things to try:
                  1. Try double-clicking the a2s.exe from Windows file explorer.
                  2. Open a command prompt in the "win" folder and try to run a2s.exe, and maybe try to convert a file - something like:
                  > .\a2s "C;\users\YOU\Downloads\test.stl"
                  Are there any errors or dialogs?
                    tmt0009
                    I'm running into the same issues as Smicha. I'm trying to import a DWG file because the SketchUp import is taking so freaking long. However I have the Ruby console pulled up and then when I select the DWG a window pops up and then disappears. The first time it created a notepad file that said "No Suitable Reader Found"
                    Any ideas?
                      driven
                      the reason I removed the pointer on the thread was I remembered it was hard to set up on a PC...
                      If you have a mac in the office, this extension is still working in v17...
                      john
                        tmt0009
                        Hey Driven,
                        I pulled this up on my laptop and ran into the same issue. I'm running SketchUp 17 and the plugin didn't do anything. Am I missing anything?
                        T.
                          tmt0009
                          I tried it on both a Windows Desktop and a Mac laptop
                            driven
                            I just re-tested on some dxf's...
                            some work others don't...
                            do your files open in tiegra viewer or converter?
                            maybe converting them back to a lower version will work...
                            john
                            • 2 / 2
