    [Plugin] Mesh Importer
    32 Posts 6 Posters 9.1k Views 6 Watching
      Jim
      @smicha said:
      Could you add obj import - this is one of the most important format.
      If you select Any File Type in the File Selection dialog, you will be able to select .obj files and import them. Textures are not supported, though. Right now I am just trying to figure out how to make it work on different operating systems and versions.
        smicha
        When I choose - any file - and select obj nothing happens.
          Jim
          Windows or Mac? What version? 32 or 64 bit?
            smicha
            win 7 64bit.
              Jim
              It would help if you could try to import the file while the Ruby Console window is open, and then post any errors here.
                smicha
                Mesh Importer Result:
                D:...\stone.obj.skp was not created.
                  Jim
                  Thanks for your patience. I just want to make sure you gave tried version 15.4 which I uploaded last evening and which fixed a similar problem kaas had?
                    smicha
                    Yes - the newest version. Feel free to ask more questions. I'd be glad to see the plugin working. For now I stick with TIG's obj importer.
                      smicha
                      BTW it seems that a cmd window blinks for a fraction of a second and does nothing.
                        driven
                        smicha, will it make one if the original is on your desktop?
                          smicha
                          It's not working at all.
                            Jim
                            Two things to try:
                            1. Try double-clicking the a2s.exe from Windows file explorer.
                            2. Open a command prompt in the "win" folder and try to run a2s.exe, and maybe try to convert a file - something like:
                            > .\a2s "C;\users\YOU\Downloads\test.stl"
                            Are there any errors or dialogs?
                            • T
                              tmt0009
                              I'm running into the same issues as Smicha. I'm trying to import a DWG file because the SketchUp import is taking so freaking long. However I have the Ruby console pulled up and then when I select the DWG a window pops up and then disappears. The first time it created a notepad file that said "No Suitable Reader Found"
                              Any ideas?
                                driven
                                the reason I removed the pointer on the thread was I remembered it was hard to set up on a PC...
                                If you have a mac in the office, this extension is still working in v17...
                                • T
                                  tmt0009
                                  Hey Driven,
                                  I pulled this up on my laptop and ran into the same issue. I'm running SketchUp 17 and the plugin didn't do anything. Am I missing anything?
                                  T.
                                  • T
                                    tmt0009
                                    I tried it on both a Windows Desktop and a Mac laptop
                                      driven
                                      I just re-tested on some dxf's...
                                      some work others don't...
                                      do your files open in tiegra viewer or converter?
                                      maybe converting them back to a lower version will work...
                                      • 2 / 2
