    [Plugin] Mesh Importer
    32 Posts 6 Posters 7.8k Views 6 Watching
      Jim
      Thanks for your patience. I just want to make sure you gave tried version 15.4 which I uploaded last evening and which fixed a similar problem kaas had?
        smicha
        Yes - the newest version. Feel free to ask more questions. I'd be glad to see the plugin working. For now I stick with TIG's obj importer.
          smicha
          BTW it seems that a cmd window blinks for a fraction of a second and does nothing.
            driven
            smicha, will it make one if the original is on your desktop?
              smicha
              It's not working at all.
                Jim
                Two things to try:
                1. Try double-clicking the a2s.exe from Windows file explorer.
                2. Open a command prompt in the "win" folder and try to run a2s.exe, and maybe try to convert a file - something like:
                > .\a2s "C;\users\YOU\Downloads\test.stl"
                Are there any errors or dialogs?
                  tmt0009
                  I'm running into the same issues as Smicha. I'm trying to import a DWG file because the SketchUp import is taking so freaking long. However I have the Ruby console pulled up and then when I select the DWG a window pops up and then disappears. The first time it created a notepad file that said "No Suitable Reader Found"
                  Any ideas?
                    driven
                    the reason I removed the pointer on the thread was I remembered it was hard to set up on a PC...
                    If you have a mac in the office, this extension is still working in v17...
                      tmt0009
                      Hey Driven,
                      I pulled this up on my laptop and ran into the same issue. I'm running SketchUp 17 and the plugin didn't do anything. Am I missing anything?
                      T.
                        tmt0009
                        I tried it on both a Windows Desktop and a Mac laptop
                          driven
                          I just re-tested on some dxf's...
                          some work others don't...
                          do your files open in tiegra viewer or converter?
                          maybe converting them back to a lower version will work...
                          • 2 / 2
