    Transform face to a known plane
    15 Posts 5 Posters 2.1k Views 5 Watching
    • G Offline
      Garry K
      I have a face that can be on any plane. I need to transform it so that it is on a specific plane. Does anyone know how to do this.
      In most cases the specific plane will be flat on the ground.
      • jolranJ Offline
        jolran
        The "specific plane" ? I assume you mean the modeling plane where the face is located to start with ?
        It says in the API
        Geom::Transformation.new(origin, zaxis)
        Don't remember if it was this one I used..
        Try: origin, a Point on the plane and zaxis should then be the plane normal.
        Edit: Be aware though that it's not really a reliable method since only providing 1 vector and not a frame. Sketchup does some thinking and comparing to decide what is supposed to become X and Y axis. So if rotation is important you have to do some extra work..
        Oh and you have to reset translation to ORIGIN before moving it to the face. I guess you could use a vector instead. Anyhew...
        If you have a plane and not a face. The plane is an Array[3] with Point and normal.
        ents = Sketchup.active_model.entities
        face = Sketchup.active_model.selection.grep(Sketchup;;Face)[0]
        gp = Sketchup.active_model.selection.grep(Sketchup;;Group)[0]
        normal = face.normal
        c = face.bounds.center
        tr1 = Geom;;Transformation.new(c,normal)
        #reset to ORIGIN
        gpc = gp.bounds.center
        tr = Geom;;Transformation.new([-gpc[0],-gpc[1],-gpc[2]], Z_AXIS)
        gp.transform!(tr1*tr)
        • G Offline
          Garry K
          The face can be rotated on both x and y axis.
          The key part is that rourke has centroid code but it only works on a face that is parallel to the ground.
          What I want to do is transform the points of the face to ground plane, calculate the centroid and then transform the centroid back so it lays on the original face.
          • sdmitchS Offline
            sdmitch
            Not sure where I found this code but it will calculate the centriod of xyz pts.
            def calc_centroid(f)
             tx=0.0;ty=0.0;tz=0.0;
             p=f.outer_loop.vertices.collect{|v|v.position}
             p.each{|v| tx+=v.x;ty+=v.y;tz+=v.z}
             ax=tx/p.length;ay=ty/p.length;az=tz/p.length
             c=Geom;;Point3d.new(ax,ay,az);#ent.add_cpoint(c)
             area = 0.0;cx = 0.0;cy = 0.0;cz = 0.0;
             for i in 0...p.length
              areat = (p[i].distance(p[i-1])*(c.distance_to_line([p[i],p[i].vector_to(p[i-1])])))/2.0
              area = area + areat;
              cx = cx + areat * ( p[i].x + p[i-1].x + c.x ) / 3.0;
              cy = cy + areat * ( p[i].y + p[i-1].y + c.y ) / 3.0;
              cz = cz + areat * ( p[i].z + p[i-1].z + c.z ) / 3.0;
             cx = cx / area;cy = cy / area;cz = cz / area;
             Geom;;Point3d.new(cx,cy,cz)
            http://sdmitch.blogspot.com/
            • G Offline
              Garry K
              Thanks sdmitch
              This indeed produces a centroid on a face.
              I also need to transform the face to ground level. The reason is I will need to do some panel optimization. So I need the shapes on ground level.
              • jolranJ Offline
                jolran
                Ok missed the the key part in the first post....
                It might be difficult to find a general solution if you want the correct X or Y rotation flat at the ground from a reversed face transformation ? Don't know if anyone found a simple solution to that unless digging in at entity level and comparing angles.
                For a simple rectangle face it might be solvable, but a complex polygon how do you tell which edge or vertice to use for alignment ? It's easier to do with parametric Surface and derivatives šŸ˜‰
                An alternative might be to use Vector3d.axes, where you form your own axes with the face.normal as Z-axis and use those with your Formulas. Might remove the need to move the face to Origin. Same problem with alignment though but when creating a tempgroup for a faceclone ( you can't move the original šŸ˜„ )its Z-axis is not pointing in the face normal direction, so there is quite some work to make the boundingbox aligned so the face is flat on the ground when reversing transformations..
                  CAUL
                  I think the code below works:
                  module AlignToNormal
                    def self.get_alignment_matrix(face_normal, p, plane_normal)
                      return Geom;;Transformation.new if (plane_normal.dot(face_normal)- 1).abs < 0.00000001
                      cv = face_normal.cross(plane_normal)
                      a = face_normal.angle_between(plane_normal)
                      return Geom;;Transformation.rotation(p, cv, a)
                    def self.get_centroid(f)
                      c = Geom;;Point3d.new(0, 0, 0)
                      f.outer_loop.vertices.map { |v| v.position }.each { |p|
                        c.x += p.x ; c.y += p.y; c.z += p.z
                      div = f.outer_loop.vertices.length
                      c.x = c.x / div; c.y = c.y / div; c.z = c.z / div;
                      return c
                    def self.main
                      mod = Sketchup.active_model
                      ent = mod.entities
                      sel = mod.selection
                      f = sel.grep(Sketchup;;Face)[0]
                      centroid = get_centroid(f)
                      m = get_alignment_matrix(f.normal, centroid, Geom;;Vector3d.new(1, 1, 1).normalize!)
                      ent.transform_entities(m, f)
                    main
                  • jolranJ Offline
                    jolran
                    That's nice but..
                    I gather this information as he actually DO want the face to the ground to do something with it there. Maybe I'm wrong this time as well.
                    Edit, sorry missed the part in the code where one can edit the plane. Your code seams to work for the purpose of getting the plane correct!
                      CAUL
                      You can concatenate transformations with multplication:
                      align = get_alignment_matrix(face_normal, centroid, plane_normal)
                      translate = Geom;;Transformation.translation(to_point - centroid)
                      align_and_translate = translate * align
                      ent.transform_entities(align_and_translate, f)
                      • G Offline
                        Garry K
                        Thanks guys - I've adjusted Caul's code and I can now get everything working the way I want.
                        • G Offline
                          Garry K
                          The plane is rotated from the ground plane on all axis.
                          • fredo6F Offline
                            fredo6
                            Usually, you achieve this with Geom::Transformation.axes.
                            In your case, assuming the face is at top level of the model:
                            tr_axe_inv = Geom;;Transformation.axes(face.vertices[0].position, *(face.normal.axes)).inverse
                            tr_axe_inv is the transformation to be used for the projection.
                            Fredo
                            • G Offline
                              Garry K
                              Thanks Fredo,
                              Seems like there is always something new to learn !!
                              • fredo6F Offline
                                fredo6
                                This projects the face on the XY plane, with vertex 0 at Origin.
                                If you wish to project to another plane, say with [pt2, normal2], use an additional direct Axe transformation.
                                Fredo
                                  CAUL
                                  Neat! Just saved fifteen lines of code in a script...
