    Transform face to a known plane
    15 Posts 5 Posters 1.9k Views 5 Watching
    • sdmitchS Offline
      sdmitch
      @garry k said:
      What I want to do is transform the points of the face to ground plane, calculate the centroid and then transform the centroid back so it lays on the original face.
      Not sure where I found this code but it will calculate the centriod of xyz pts.
      def calc_centroid(f)
       tx=0.0;ty=0.0;tz=0.0;
       p=f.outer_loop.vertices.collect{|v|v.position}
       p.each{|v| tx+=v.x;ty+=v.y;tz+=v.z}
       ax=tx/p.length;ay=ty/p.length;az=tz/p.length
       c=Geom;;Point3d.new(ax,ay,az);#ent.add_cpoint(c)
       area = 0.0;cx = 0.0;cy = 0.0;cz = 0.0;
       for i in 0...p.length
        areat = (p[i].distance(p[i-1])*(c.distance_to_line([p[i],p[i].vector_to(p[i-1])])))/2.0
        area = area + areat;
        cx = cx + areat * ( p[i].x + p[i-1].x + c.x ) / 3.0;
        cy = cy + areat * ( p[i].y + p[i-1].y + c.y ) / 3.0;
        cz = cz + areat * ( p[i].z + p[i-1].z + c.z ) / 3.0;
       cx = cx / area;cy = cy / area;cz = cz / area;
       Geom;;Point3d.new(cx,cy,cz)
      http://sdmitch.blogspot.com/
        Garry K
        Thanks sdmitch
        This indeed produces a centroid on a face.
        I also need to transform the face to ground level. The reason is I will need to do some panel optimization. So I need the shapes on ground level.
        • jolranJ Offline
          jolran
          Ok missed the the key part in the first post....
          It might be difficult to find a general solution if you want the correct X or Y rotation flat at the ground from a reversed face transformation ? Don't know if anyone found a simple solution to that unless digging in at entity level and comparing angles.
          For a simple rectangle face it might be solvable, but a complex polygon how do you tell which edge or vertice to use for alignment ? It's easier to do with parametric Surface and derivatives 😉
          An alternative might be to use Vector3d.axes, where you form your own axes with the face.normal as Z-axis and use those with your Formulas. Might remove the need to move the face to Origin. Same problem with alignment though but when creating a tempgroup for a faceclone ( you can't move the original 😄 )its Z-axis is not pointing in the face normal direction, so there is quite some work to make the boundingbox aligned so the face is flat on the ground when reversing transformations..
            CAUL
            @garry k said:
            I have a face that can be on any plane. I need to transform it so that it is on a specific plane. Does anyone know how to do this.
            In most cases the specific plane will be flat on the ground.
            I think the code below works:
            module AlignToNormal
              def self.get_alignment_matrix(face_normal, p, plane_normal)
                return Geom;;Transformation.new if (plane_normal.dot(face_normal)- 1).abs < 0.00000001
                cv = face_normal.cross(plane_normal)
                a = face_normal.angle_between(plane_normal)
                return Geom;;Transformation.rotation(p, cv, a)
              def self.get_centroid(f)
                c = Geom;;Point3d.new(0, 0, 0)
                f.outer_loop.vertices.map { |v| v.position }.each { |p|
                  c.x += p.x ; c.y += p.y; c.z += p.z
                div = f.outer_loop.vertices.length
                c.x = c.x / div; c.y = c.y / div; c.z = c.z / div;
                return c
              def self.main
                mod = Sketchup.active_model
                ent = mod.entities
                sel = mod.selection
                f = sel.grep(Sketchup;;Face)[0]
                centroid = get_centroid(f)
                m = get_alignment_matrix(f.normal, centroid, Geom;;Vector3d.new(1, 1, 1).normalize!)
                ent.transform_entities(m, f)
              main
            • jolranJ Offline
              jolran
              That's nice but..
              I gather this information as he actually DO want the face to the ground to do something with it there. Maybe I'm wrong this time as well.
              Edit, sorry missed the part in the code where one can edit the plane. Your code seams to work for the purpose of getting the plane correct!
                CAUL
                You can concatenate transformations with multplication:
                align = get_alignment_matrix(face_normal, centroid, plane_normal)
                translate = Geom;;Transformation.translation(to_point - centroid)
                align_and_translate = translate * align
                ent.transform_entities(align_and_translate, f)
                  Garry K
                  Thanks guys - I've adjusted Caul's code and I can now get everything working the way I want.
                    Garry K
                    The plane is rotated from the ground plane on all axis.
                    • fredo6F Offline
                      Usually, you achieve this with Geom::Transformation.axes.
                      In your case, assuming the face is at top level of the model:
                      tr_axe_inv = Geom;;Transformation.axes(face.vertices[0].position, *(face.normal.axes)).inverse
                      tr_axe_inv is the transformation to be used for the projection.
                        Garry K
                        Thanks Fredo,
                        Seems like there is always something new to learn !!
                        • fredo6F Offline
                          This projects the face on the XY plane, with vertex 0 at Origin.
                          If you wish to project to another plane, say with [pt2, normal2], use an additional direct Axe transformation.
                            CAUL
                            Neat! Just saved fifteen lines of code in a script...
