    Wrap tool available ?
    6 Posts 4 Posters 7.7k Views 4 Watching
    • W Offline
      WOFF3D
      Does anyone know if there is a wrap tool available somewhere. For instance, when obtaining a 3D house model (or car) with all interior inside and you ONLY want to 3D print the outer contour (in a specific thickness), you definitely would like some kind of a wrap tool for that.
      Any suggestions ?
      • oceanembersO Offline
        oceanembers
        I'm not aware of any such plugin. For a manual method, if your individual pieces are solid, you could try a subtracting them all from a cube. No idea how well this would work.
        • sdmitchS Offline
          sdmitch
          @woff3d said:
          Any suggestions ?
          Using the Section Plane, right click on it and choose "Create Group From Slice". Erase the Section Plane, edit the created group and erase everything inside.
          http://sdmitch.blogspot.com/
          • W Offline
            WOFF3D
            Thanks. Section plane is a too simple approach. SuSolid or Solid Inspector2 is probably the closest to what I look for but even those won't wrap easy. Just wrap, no questions asked ....
              Jim
              I think the I-materialize extension has a shell feature. Find it in the Extensions Warehouse.
              • W Offline
                WOFF3D
                Hi Jim,
                Thanks for your answer. I always use https://netfabb.azurewebsites.net/ which is great, but an external step. I would like to wrap within SU because stl im- and export always takes a lot of time AND removes layer/material data.
