    Not manifold
    4 Posts 3 Posters 504 Views 3 Watching
    • X Offline
      xdejvid
      Hello, can we crate right solid with Soap Skin & Bubble and Fredo6 jointpushpull? I need volume for this solid and stl file.
      http://shrani.si/f/1p/la/4meUZ6E8/1.jpg
      http://shrani.si/f/2Y/CJ/1DJJx4m0/2.jpg
      Solid inspector error, he can not repair the lines.
      • cottyC Offline
        cotty
        From the images I think there are at least two problems:
        • wrong face orientation
        • a group inside
        (You can try the newer version of SolidInspector)
        my SketchUp gallery
          Soap Skin Bubble creates a group for the surface. Explode that group and you should be able to have a solid. And Cotty is correct. You need to reverse the face on that mesh.
          • X Offline
            xdejvid
            thanks! solved πŸ˜„
