    A3 pdf into sketchup inkspace
    3 Posts 3 Posters 715 Views 3 Watching
    • P
      Poot
      Hi guys,
      I need to import a pdf file from a a3 plan into sketch up.
      I'm using windows so sketchup cant directly import pdf file's,
      so i downloaded inkspace to convert it.
      I open the pdf file in inkspace then save it like png. Import in sketch up as image,
      but than my plan comes out very unsharp, i can not draw on the plan to make it 3D.
      What am i doing wrong ore are there better other options.
      Thanks in advance ,
      Sam
      • K
        kaas
        If the original pdf uses lines and not images, from inkscape you can also export as dxf. Import the dxf in SketchUp (must be pro) and you can snap to the edges and endpoints
        • ely862meE
          ely862me
          For sharper images go to Window/Preferences/OpenGl and check Use maximum texture size.
          Elisei (sketchupper)
          Come and See EliseiDesign
