    Fur not even
    9 Posts 4 Posters 701 Views 4 Watching
      LARV
      Hello!
      I have this problem making fur grow even over a bent surface. It seems the grass in my scence follows the surface "lines". Sorry, I don´t know what these are called, but I can´t erase them using soft erase.
      Is there a way to make the surface even so the spread of grass grows even as well?
      • cottyC Offline
        cotty
        Probably your maximal number of objects per face is too small?
        (I can't wait for Skatter any longer 😉 )
        my SketchUp gallery
          LARV
          Strang how your surface seems even. I did the same and it was somewhat more even but far from acceptable.
          Isn´t there a better way?
            LARV
            If a draw lines similar to the dotted ones I can´t seem to remove I get close to equal surfaces (area). It will now grow even, but this is not optimal.
            • JQLJ Offline
              JQL
              You've got two controls. Max number per face and density.
              If density is 1 per m2 you got an object each m2.
              A face with 2m2 will get 2 objects, a face with 2m2 will get 4 objects and so on...
              If you have max number set to 4 AND density of 2 per m2, a face of 1m2 get's 2 objects, a face of 2m2 gets 4 objects, a face 3m2 get's 4 objects and a face with 100m2 still get's 4 objects.
              That's why splitting the face makes your settings create a better distribution. You should increase max number.
              www.casca.pt
              Visit us on facebook!
              • cottyC Offline
                cotty
                The example number of 2000 depends on the shown surface (mine was 5mx5m?, didn't save it), if your face is bigger, you should increase it more.
                my SketchUp gallery
                  LARV
                  I will try this. Thanks.
                  And thanks to Cotty as well of course.
                    You have this one also! 😉
                    (free version is existing)
                      LARV
                      Yep, I use that plugin as well. For trees.
