    CutMap
    2 Posts 2 Posters 830 Views 2 Watching
    • robertWanR Offline
      robertWan
      Can someone aid me - why is this plugin not working?
      CutMap. http://www.labyrinthware.com/
      It's also in the SketchUcation Plugin Store.
      After installing, in SU 8 (Win XP64), a window like this appears.
      As well as in SU 8 (Win7).
      It's launching in Su 2014 (Win XP64), but the plugin window is empty.
      How is it working for you?
      Robert
        It is looking for a file to 'require' that is called: /bin32/binary
        Unless there is a file in that named subfolder [in the Plugins folder or other folder listed in the $: ], then using that file-path will fail...
        I don't have this plugin...
        Assuming you installed exactly as its instructions... I suspect that the binary.so file within the bin32 folder is compiled to 32bit and you are using 64bit or an old [unsupported] XP version ??
        If so contact the author directly to see if there's a 'bit-ness' fix in the pipeline...
