    Using SmartDrop
    2 Posts 2 Posters 325 Views 2 Watching
    • P Offline
      PopoLand1
      How to keep component from rotating to align to applied surfaces?
        slbaumgartner
        This sounds like the component has the glue-to behavior set. Open the Components window, click the little house icon to see "In Model", select the component and then select edit in the component window. If you see Glue To set to anything except "None", you need to change this to eliminate the glueing behavior. Note: if you originally draw the component up against another face, this behavior is set automatically unless you unselect it in the create component dialog.
