    3D Truss Models
    1.5k Posts 31 Posters 954.8k Views 30 Watching
    • medeekM Offline
      medeek
      This is the first new icon for the main Truss plugin toolbar in quite some time:
      http://design.medeek.com/resources/images/truss_su_menu_active.jpg
      The complex roof icon/tool will allow the user to pick between either a truss or rafter complex roof (first HTML menu), then the user will select a horizontal (closed) face which will be used to determine the perimeter of the roof. Before the user selects the outline face they can utilize the complex roof draw menu (HTML menu #2) to adjust settings (ie. overhang, pitch, sheathing, cladding etc...)
      The draw menu will stay open and the tool active until closed or space bar is pressed. So multiple complex roofs can be created one after another with the given settings. Similar to the wall plugin I will probably implement a system of roof presets so the user can quickly jump to a specific configuration.
      My latest code for menus in the Electrical plugin is my cleanest and most advanced code for dealing with interactive HTML menus. I will be borrowing heavily from this plugin initially to setup my basic tool and menu systems.
      I will also at some point allow the user to select the points that define the roof outline rather than selecting a face but for the time being I'm going to keep it simple and just allow the face selection method for now.
      I am starting with the complex rafter roof first. The truss variant will be even more troublesome and problematic so its best to cut my teeth on the rafter variant and see how far I can take it.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The first menu will use the following two images to select either a rafter or truss roof:
        http://design.medeek.com/resources/images/COMPLEX_ROOF_RAFTER_240.png
        http://design.medeek.com/resources/images/COMPLEX_ROOF_TRUSS_240.png
        design.medeek.com
        • medeekM Offline
          medeek
          First look at the initial selection menu:
          http://design.medeek.com/resources/trussplugin/images/truss_su442_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            When you initially create the complex rafter roof all plate heights, rafter depths, pitches and birdsmouth cuts will be the same for each eave/roof plane. Then I would like to have a system whereby the user can potentially edit each and every eave, changing up these parameters as they desire as well as switching certain hip planes to gable or vice versa.
            Additionally it will be useful to have a system wherein you can also edit the underlying outline that defines the entire roof. This latest module is not going to come easy but if I can pull it off it will be a very nice tool.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.4.7 - 06.13.2019
              • Enabled a "No Framing" mode for gable, hip and shed rafter roofs. This feature is also available for asymmetric gable and hip roofs.
              • Added the complex roof icon to the main toolbar.
              http://design.medeek.com/resources/trussplugin/images/truss_su443_800.jpg
              http://design.medeek.com/resources/trussplugin/images/truss_su444_800.jpg
              The "no framing" mode is per customer requests. I'm really not sure how much utility this features offers but it certainly will keep your model more lightweight if you choose not to show all of the rafter framing.
              I also added this parameter in preparation for the upcoming complex roof module. With complex roofs the ability to eliminate all of the underlying framing will be a much bigger factor in my opinion.
              design.medeek.com
              • medeekM Offline
                medeek
                View comparison models here:
                3D Warehouse
                3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                (3dwarehouse.sketchup.com)
                versus:
                3D Warehouse
                After your purge the models there is not really a huge difference in file size between the two.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Just an FYI, some of the recent updates have managed to break a few things in the metric side of the plugin. I will be working on these issues all of today (and tomorrow if necessary) and release the fix later this evening or Saturday morning. I apologize for the inconvenience.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.4.7b - 06.14.2019
                    • Addressed a number of critical bug fixes for metric templates.
                    If you are working with metric units this update will address a number of issues that were not resolved when the edit function was added to various trusses and rafter roofs. This is an essential upgrade.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Still trying to get the complex roof module up and running but every time I try and refocus some other fire comes along and pulls me sideways. The soffit and fascia module introduced another block of parameters which need to be exposed in the global settings so users can set their default behavior, this is a relatively easy addition. I will knock this one out sometime later this evening.
                      With the Wall plugin I also have a huge list of items but a couple which are actively being requested are stacked windows and a custom offset parameter for the stud spacing. I really should hop back into the Wall plugin and try to address these before I get re-focused on the complex roof module.
                      The recent metric fix will be a welcome upgrade/resolution for many of you using metric templates. Again, I apologize for not spending as much time as I would like on debugging the metric side of the house. I will try to make a more concerted effort to check the metric side moving forward.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I thought my job is hard, imagine having to frame something like this up:
                        https://scontent-sea1-1.xx.fbcdn.net/v/t1.0-9/62924013_1291590131006209_2467017407957303296_o.jpg?_nc_cat=101&_nc_eui2=AeF-9ckY55PDcK1SuPuXpup9cB2ROFlLBLNsmBCwu5NT9seqf8ut5-4raXO5JrHV6uRsdRyrveaK-_fVcF7kQyPFdZItbSMS9vIOs1-dcC8xxg&_nc_oc=AQk5ud8HaAFCPFKSt02hzn6aTNJgo7GKPTjpp1Y4pKxhmfFaZUB64qw2LLKWpucHXiY&_nc_ht=scontent-sea1-1.xx&oh=c95ee81c3e97f0bbaba00bc6c3c498dd&oe=5DC3BD8E
                        design.medeek.com
                          MtnArch
                          An example of "Just because you can think it and draw it does NOT make it worth constructing in the real world!!"
                          Highest Regards,
                          Alan T. Hendry, RA
                          Architect
                          • medeekM Offline
                            medeek
                            Version 2.4.8 - 06.16.2019
                            • Added a Soffit/Fascia tab to the Global Settings.
                            http://design.medeek.com/resources/trussplugin/images/truss_su445_800.jpg
                            I've been developing this plugin now for almost 4 years. Progress is steady but much yet remains to be done. Once the complex and secondary roof modules are operational this plugin will begin to compete with the big dogs of architectural software (eg. Revit, Chief Architect etc...) Its taken a while to get to this point with a few detours along the way but I'm getting very close to accomplishing the holy grail of the plugin which has always been the ability to handle complex roofs automatically.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              With the recent post about the foundation plugin (adding in parametrics for slab on grade foundations) some people are asking "Why did you stop working on complex roofs and move back to the foundation plugin?". As it turns out the algorithm or logic for editing the "polygon" outline of a complex roof or foundation is pretty much the same. Since I have the overall code in place for a slab on grade foundation I am first implementing the polygon face edit tool with the foundation plugin then I will bring this code over to the Truss plugin and complex roofs.
                              design.medeek.com
                              • jujuJ Offline
                                juju
                                Could you kindly work through your code and ensure that when someone is working in metric they don't encounter any fields to be entered in inches (or the like)? I have version 2.4.8c and was using common truss, got to advanced settings, at the ceiling parameters and somehow ended up facing fields with inches entry requirements.
                                • medeekM Offline
                                  medeek
                                  I will take a look at that. There may be a few advanced option menus that only allow for imperial entry. Off the top of my head I don't remember which one it is but I do recall that one of them still does not allow for full metric entry. Thank-you for bringing this issue to the top.
                                  When you edit an assembly in metric are you getting any non-metric parameters coming up?
                                  design.medeek.com
                                  • jujuJ Offline
                                    juju
                                    I get metric for the most part, just the advanced that seems to kick out into imperial.
                                    Your Timber Truss option (bottom right) still doesn't accept metric at all.
                                    • medeekM Offline
                                      medeek
                                      I will look at this module as well. When I initially setup the timber truss module I thought it would be a big hit, but then I received literally zero feedback on it. I assumed it simply was not being used by the vast majority of users so I probably did not see any urgency to provide the metric side to this module at the time.
                                      I will jump on it, and see what I can do.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        The "FRONT" option for Gable Truss parameter allows one to terminate a truss assembly where it meets another roof or wall but currently it does not provide for a GIRDER truss as shown:
                                        http://design.medeek.com/resources/trussplugin/images/truss_su465_800.jpg
                                        I need to provide an additional option here called "GIRDER" which allows the user to terminate the truss assembly and also configure a girder truss (ie. Howe truss with heavy bottom chord and stubbed off tails).
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.4.9 - 08.27.2019
                                          • Fixed the trim tool so that it is now able to trim hollow sections (ie. pipes, rectangular tubes).
                                          http://design.medeek.com/resources/images/wall_su271_800.jpg
                                          The extend tool already had this ability but for some reason I was not made aware that the trim tool was unable to handle hollow sections until just recently.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Medeek Live Training: Session 2
                                            Scheduled time is Sept. 12 (Thursday) at 11:00 PST
                                            The primary topics covered will be the recent additions to the truss plugin (ie. soffit & fascia, asymmetric rafter roofs, etc...) however as usual I will be open to any other questions via the online chat.
                                            The session should run about an hour in length depending on the number of questions I receive.
                                            I think I've worked the kinks out of my streaming software, so things should go a bit smoother this time.
                                            design.medeek.com
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 75
                                            • 76
                                            • 61 / 76
