    3D Truss Models
    1.5k Posts 31 Posters 954.8k Views 30 Watching
    • medeekM Offline
      medeek
      Using the Medeek Truss Plugin and the housebuilder plugin I was able to create this simple model in about 3 minutes:
      http://design.medeek.com/images/misc/testhouse1.jpg
      I would like to be able to create this type of model in the future:
      http://design.medeek.com/images/misc/BARN5030-A6D-2_ROOF_FRAMING.jpg
      This model was created in Solidworks and probably took a day or two to assemble. Notice the gambrel attic and the gable end trusses. That ability I would like to add into the plugin.
      This next model was also created in Solidworks and only shows the foundation and framing, the entire model represents about a month of work including the drawing set.
      http://design.medeek.com/images/misc/GARAGE4828-A6D-3_FRAMING1.jpg
      I would like to see a plugin that is capable of generating this level of structural detail in a couple of hours instead of weeks. Is this possible?
      On a related note, does a plugin exist for creating SOG and stemwall foundations?
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've got gable end trusses working for king post trusses:
        http://design.medeek.com/resources/images/truss_su12_800.jpg
        I haven't made this latest update live just yet as I need to update all of the other truss types to make sure it does not break anything.
        The other thing I am changing is the second user prompt box that allows one to enter in the number of trusses. I have now switched to a building length and the logic spaces the trusses based on the this length and the truss on center spacing. Gable end trusses can be switch on or off. Spacing of the gable studs is another user input.
        design.medeek.com
        • jujuJ Offline
          juju
          wow, this plugin is developing at an incredible rate, thanks!
          For general designer use, I would think the plugin functions pretty well for now, personally I would shift focus to the positioning for now. Once that's sorted, move back into developing and expanding the truss configuration options.
          • medeekM Offline
            medeek
            I have a question or request for our Mac/Apple users. Has anyone tried using the plugin on a Mac. I don't have access to a Mac so I have no way of testing the plugin to see if it actually might work on this platform. If someone would be willing to test it out for me I have no problem in setting them up a permanent license and sending them the full version of the plugin, this would help me out a lot.
            I've had to take a bit of a break from my coding, too much local work to process and never enough time in the day to get everything done.
            As Juju suggests, I am going to try and figure out a better positioning mechanism before I start adding more truss types or additional features. This is the biggest thing holding the plugin back right now.
            design.medeek.com
            • deaneauD Offline
              deaneau
              @medeek
              Positioning: It would be really nice to drop the truss set right into place by clicking the location with the mouse.
              could be this is usefull
              SketchUp Extension Warehouse
              Your library of custom third-party extensions created to optimize your SketchUp workflow.
              (extensions.sketchup.com)
              MADE, BORN AND LIVING IN BERLIN
              Big Thank You to all Programmers
              Some German words are so long that they have a perspective. M.Twain
              • medeekM Offline
                medeek
                Version 1.0.7 - 11.03.2015
                Trusses can now be positioned and sized via three mouse clicks, with the option for manual overide in the dialog windows.
                The number of trusses is now based on the spacing and building length.
                Floor trusses with top chord bearing now are positioned properly.
                Hopefully I haven't broken the metric inputs with the latest revision. I will test further tonight but so far its looking really good.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.0.7 took a while to pop out. The big improvement is the ability to click with the mouse at three corners and place the truss set without any additional rotating or translating.
                  In literally seconds I can now put a floor and a roof on 4 walls using the truss plugin and the Homebuilder plugin:
                  http://design.medeek.com/images/MISC/testhouse2.jpg
                  Of course the gable walls are not quite right but you get the idea. I may have slightly misunderestimated (a word created by GW Bush) SketchUp and what one can do with it.
                  The biggest hurdle was to learn how to create and properly set up a "tool" within the API. Adding different truss types is much more fun than working through that mess.
                  I'm also thinking it might be useful to have an option to put sheathing on the roof and/or floor?
                  I'm also looking for a good plugin that does stemwall and slab on grade foundations, if anyone has recommendations please advise. I may use my own plugin for my own practice in order to quickly mock up certain structures and provide visuals. With the right tools I think SketchUp can be a very effective and quick turnaround platform
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    thanks!
                    • medeekM Offline
                      medeek
                      Version 1.0.8 - 11.04.2015
                      • Added Weyerhauser TJI® I-joists: 110, 210, 230, 360, 560, 560D.
                      • Rim joist option enabled for TJI floor joists.
                      http://design.medeek.com/resources/images/truss_su13_800.jpg
                      http://design.medeek.com/resources/images/truss_su14_800.jpg
                      Only a rectangular configuration is available currently. If I can figure out how to code a polygon version of this that would be much more impressive (ie. pick the points that define the perimeter of the foundation and the plugin generates the complete floor layout).
                      This is straying a bit from trusses but I figured if I'm going to include floor trusses I might as well make floor joists available as well, just a small bit of code to get there.
                      design.medeek.com
                        driven
                        @medeek said:
                        ...Has anyone tried using the plugin on a Mac...
                        I have tested a few version of the trial on mac running Yosemite...
                        PM me if you have specific questions or want me to test the latest version...
                        john
                        • pbacotP Offline
                          haha--where's my comment? I was thinking of saying: add truss joist and solid lumber (as the floor trusses wouldn't be used on a lower floor like that). Then I thought you had enough to do! So I didn't post. Good work!
                          After years and years I still cannot get the programmer for another app I use to add engineered lumber options.
                          • medeekM Offline
                            medeek
                            I'm considering adding the following advanced options to roof trusses:
                            1.) Sheathing
                            2.) Fascia
                            3.) Rake Board (Gable Overhang)
                            4.) Outlookers (Structural vs. Non- Structural, Horizontal vs. Vertical)
                            5.) Vent Blocks
                            6.) Gable End Trusses (Already in progress: Dropped top chord and structural variants)
                            This would then provide a fairly complete roof framing solution.
                            For floor trusses (adv. options):
                            1.) Sheathing
                            2.) Gable End Floor Truss (Ladders)
                            3.) Ribbon Board
                            For floor joists [TJI and dimensional lumber] (advanced options):
                            1.) Sheathing
                            2.) Midspan blocking at user selected bearing points.
                            3.) Sill Plate (for floor framing on top of concrete foundations)
                            Please suggest other options that might be handy to have.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I thought about multi-ply girder trusses but I think for now it is not too hard for the user to simply create another instance of the truss component and manually stack them up to create double or triple ply trusses.
                              Another interesting thought I had is what would it take to codify an algorithm for creating a typical dormer:
                              http://design.medeek.com/images/MISC/GARAGE4828-A6D-3_DORMER1.jpg
                              However, this may be a bit ambitious at this point but I think it could be done.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                In my neck of the woods we don't typically use dimensional lumber alot for floor framing anymore. Most of what I see is I-Joist products with LVL or LSL rimboard.
                                For those that still use dimensional lumber what is the common practice for the rim joists? I'm assuming that it is the same as the rest of the joists in the floor (ie. 2x8, 2x10 or 2x12).
                                design.medeek.com
                                • pbacotP Offline
                                  We use both--particularly for the first floor over a crawl space, lumber can be economical. The rim joist is the same.
                                  • medeekM Offline
                                    medeek
                                    Version 1.0.9 - 11.05.2015
                                    • Added separate toolbar icons for floor trusses and joists.
                                    • Created separate submenu items under the Medeek Truss Plugin Extension for roof and floor trusses.
                                    The main menu was getting a bit cluttered and not so user friendly so I split it out into "Roof" and "Floor", hopefully this makes more sense.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      As I've been contemplating adding gambrel attic trusses to the truss plugin I've had to give some thought to what constitutes a good gambrel design. I've looked into this before but my conclusion is that no matter the lower and upper pitch of the roof a good looking design seems to be always achievable if the lower and upper legs of the roof are more or less equal in the length. To that end I've devised a simple spreadsheet calculator that will quickly throw out the numbers and display a graphic of the gambrel profile:
                                      http://design.medeek.com/resources/gambrel/GAMBREL_ROOF_CALCULATOR.jpg
                                      I'm not saying this is a hard and fast rule but it seems to give decent results. Minor variations (ie. L1 not equal to L2) are generally okay but if one leg is significantly longer than the other the gambrel profile becomes distorted.
                                      The math to come up with this equality and generate the coordinates of the overall roof height and the pitch break is rather interesting and for those mathematically inclined is given below. Note that the equation ends up being a quadratic equation with the positive root extraneous:
                                      http://design.medeek.com/resources/gambrel/GAMBREL_EQN1.jpg
                                      http://design.medeek.com/resources/gambrel/GAMBREL_EQN2.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I'm working on the advanced options for roof trusses and I'm looking at the fascia board. I've come up with three different configurations for the fascia that I've seen in practice and in the architectural books that I have.
                                        Which method of the three below do you prefer? or is there another configuration that I have missed?
                                        http://design.medeek.com/images/misc/FASCIA_OPTIONS.jpg
                                        Note that I am only interested in the sub fascia if there are additional trim boards that is up to the architect or designer.
                                        design.medeek.com
                                        • KrisidiousK Offline
                                          Krisidious
                                          I prefer 1 and 2
                                          I would take it a bit further or leave it simple, those that want more detail can use a number of paid plugins or free ones to route fascia profiles. but for doing fascia those plugins don't take in to account the subtleties of "following" a fascia path. certain sides and corners and what not are done quite differently with the same styling.
                                          But one of my most common fascia combos ranges from 1x8 with a 1x4 added to it's face or I might even taller up to 10" or maybe 12" with 6 or 8" facing it.
                                          up to you... you've already created quite a product.
                                          By: Kristoff Rand
                                          • medeekM Offline
                                            medeek
                                            I think I will include the option for either of the 3 variants since it isn't too much more to code and I'm getting quite a mixed reaction from different builders and designers. I guess everyone has there preferred method.
                                            Another quite common fascia treatment is to use a 2x6 sub fascia with a 1x8 finish fascia (primed spruce or cedar).
                                            However, I am mostly interested in the sub fascia and then I'll leave it up to the designer/architect to dress it up further as needed.
                                            I'm trying to make the roof framing as easy as possible and basic structural items such as trusses, fascia, outlookers are all automated, then the designer can concentrate on the finish work (ie. ridge caps, trim fascia, barge boards, cupolas).
                                            design.medeek.com
                                            • 6
                                            • 7
                                            • 75
                                            • 76
                                            • 5 / 76
