    3D Truss Models
    1.5k Posts 31 Posters 978.6k Views 30 Watching
    • medeekM Offline
      medeek
      I could add in an advanced option to model in the plates but for now it would be non-engineered and simply for representational purposes. If I have requests from other users for this sort of thing I will consider it.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        Thanks for the update Nathaniel. Again version numbering is conflicting with a prior version, also date stamp on the site differs from the post above. Any chance you could have an unique version number to every version you release, even if the change/update is however minor?
        • medeekM Offline
          medeek
          Version 1.3.1 - 02.17.2016
          • New submenu item and toolbar icon added for global settings.
          http://design.medeek.com/support/trusspluginmanual/images/truss_su_menu_active.jpg
          I've also addressed a number of bugs for rafter roofs when metric units are being used. I highly recommend everyone download the latest version, especially if you are using metric units.
          design.medeek.com
          • medeekM Offline
            medeek
            Yes, I should probably roll a new rev. even when I make minor changes. The new menu item is really a partial update since I haven't yet add all of the code behind it so I didn't think it worth a new revision number. However, the bug fixes I just made are significant. I will be more strict about this in the future.
            Date stamp on revision is now 02.17.2016
            design.medeek.com
            • medeekM Offline
              medeek
              Started to code in the dual pitch truss, the top chords, king post and bottom chord are there just need to add some webs:
              http://design.medeek.com/resources/images/truss_su73_800.jpg
              Just an FYI, my previous post in Nov. had a sign switched in the last step of the derivation for Span 1, corrected in the plugin to a minus sign and everything is comes out perfect.
              design.medeek.com
              • medeekM Offline
                medeek
                Here is a Dual Pitch 2/2 - 3/3 truss with a 12:12 pitch and a 4:12 pitch.
                http://design.medeek.com/resources/images/truss_su74_800.jpg
                Still working on the gable end trusses and the advanced options involving structural outlookers.
                I will be looking at raised heel scissor trusses next, those sound challenging and interesting. Please post or send me examples of any raised heel scissor truss examples or shop drawings. The combined pitches of the top and bottom chord with a wedge, slider or vertical web and strut will require some serious calculations and ample logic.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.3.2 - 02.23.2016
                  • Added Dualpitch truss type, configurations: (2/2-3/3).
                  • Metric input enabled for dualpitch truss type.
                  • Advanced options enabled for dualpitch truss type.
                  http://design.medeek.com/resources/images/truss_su75_800.jpg
                  View model here:
                  3D Warehouse
                  3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                  (3dwarehouse.sketchup.com)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Mono Cathedral trusses with heel wedge:
                    http://design.medeek.com/resources/images/truss_su76_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      A quick study of the general shape and layout of a 6/6 bowstring truss with different radii:
                      http://design.medeek.com/images/MISC/BOWSTRING1.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.3.3 - 02.28.2016
                        • Added Bowstring truss type, configurations: (6/6).
                        • Metric input enabled for bowstring truss type.
                        http://design.medeek.com/resources/images/truss_su77_800.jpg
                        View model here:
                        3D Warehouse
                        I'm not sure how common place this truss type is anymore so I will add the advanced options at a later date if requested by a user. I can also add in other configurations with more panels if needed (ie. 8/8, 10/10).
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Added Bowstring truss type, configurations: (8/8).
                          http://design.medeek.com/resources/images/truss_su78_800.jpg
                          View model here:
                          3D Warehouse
                          Initially I wasn't really sure how to lay out this type of truss, especially the webs and panel distances. Then after some thought it occurred to me that the length of each top chord segment should be roughly equal to best approximate the circular shape of the truss. After some checking of existing shop drawings my theory tested correct. The length of each top chord segment is equal in length.
                          The necessary math and algorithm was much simpler than I initially thought. Another sidenote, as the radius of the truss decreases the pitch breaks of the truss become more apparent and the circular shape of the roof becomes more angular.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            28' Bow Barrel Truss (8/8) study.
                            http://design.medeek.com/resources/images/truss_su79_800.jpg
                            View model here:
                            3D Warehouse
                            Gable end trusses for this type are a bit of a question right now. I can add this one into the plugin if there is some call for it, but I may hold off until a request is made since the code will be somewhat tedious with all the separate members that make up the top and bottom chords.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.3.4 - 03.02.2016
                              • Corrected a bug in the metric unit template module.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.3.5 - 03.04.2016
                                • Added Bow Barrel truss type, configurations: (8/8).
                                • Metric input enabled for bow barrel truss type.
                                • Corrected a bug with the webs of the bowstring truss type.
                                http://design.medeek.com/resources/images/truss_su80_800.jpg
                                View model here:
                                3D Warehouse
                                Gable end option is also available (not shown in image above for clarity) for this truss type.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  I find the bow barrel truss very interesting. Its very similar to a flat truss in a lot of respects but then you essentially create pitch breaks at all the panel points and add some camber to it.
                                  https://scontent-sea1-1.xx.fbcdn.net/hphotos-xaf1/t31.0-8/12828943_1277725908908068_139963240902266978_o.jpg
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I'm thinking the next thing I might tackle is an octagonal rafter roof. Something along these lines:
                                    http://www.sbebuilders.com/octagon/octagon_top_front.jpg
                                    My time allotted to work on the plugin is very limited right now so I'm trying to decide if this would be something of interest for current and potential users of the plugin.
                                    design.medeek.com
                                    • facerF Offline
                                      facer
                                      Medeek Truss - Nathaniel
                                      A half octagon roof would be useful for greenhouses, tea rooms, and extensions to existing
                                      houses, cafes and small offices. (refer to screencapture with red section marks)
                                      I have been following your plugin using the "trial version" and a few thoughts come to mind:
                                      **1. Keep it Simple (stupid). (KISS)**   No offence intended, it is a common "Check - design" mnemonic or mental stamp used with every new idea or concept.
                                      Offering too many options although good can work against you until your market is tested.
                                      Feedback is required as you may be going off into areas that users have little interest in.
                                      If your market is architects, builders and designers; remember they chose their profession because
                                      they have an interest in that area, not structural engineering. Of course there is a crossover but I bet most in the above list are mainly interested in how the truss affects their area of focus.
                                      **2. Graphics help and assists in data input**.  A good example to view is the "1001 bits" plugin.
                                      Graphics are important to aid the "non-engineer".
                                      Colour, blocking of information that are linked or share associated areas would help.
                                      Lists of data input are difficult to follow as there is no "road map" to where
                                      it is leading.
                                      **3. Preset options**with data toned in colour or grey with limited options for changes to key variables in white or a colour. ( e.g. roof slope angle) This would allow the user at a glance to focus in on set options.
                                      **4. Truss design and engineering computations** are generally handled by "truss fabricators" here in Australia.  Their CAD drawings, computations and fabrication are part of their "full package software".
                                      **5. The strength in your truss plugin is** allowing the architect, builder, client or designer, to understand better the likely design and construction issues for different truss options.
                                      I congratulate you on your enthusiasm and I enjoy checking every few days
                                      on what new truss you have considered.
                                      All the best with your plugin.
                                      Half octagone roof for Green houses, tea rooms and extensions.
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.6 - 03.06.2016
                                        • Added Double Howe and Triple Howe common truss types.
                                        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Double & Triple Howe) truss types.
                                        http://design.medeek.com/resources/images/truss_su81_800.jpg
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          @facer
                                          Thanks for the in depth feedback.
                                          I think I might start with a full octagon roof (gazebos, greeenhouses) and then look at doing a half octagon. I need to give this a bit more thought.
                                          1.) I agree too many options just slow the user down to the point that the software becomes clunky and hard to use. I've tried to minimize this by using an "advanced options" selection so that one can quickly generate geometry without being overly concerned with too many options and settings all at once.
                                          2.) Part of the problem I think is that I am using the simple UI for my input prompts and I need to go to an html user input that I can better customize to my plugin. With html inputs I can provide better prompt and graphics.
                                          3.) I have started working on the global settings (icon is in place). This will allow the user to setup certain variables to commonly used values. Along with this I am also considering other preferences like layer assignment.
                                          4.) The truss engineering portion is very limited at this point and generally is only of value to a very specific crowd of users. Once I add in plywood gusset plates it will be much more useful to builders and DIYers who want to site build their own trusses. However, that will probably not be complete for another few months.
                                          5.) The plugin has expanded to not only include roof trusses but also floor framing, floor trusses, and rafter framing. The hip roof framing needs considerable attention to make it more flexible and allow for complex roof construction.
                                          My biggest problem is finding the time right now to really make some serious improvements to the plugin. The UI makeover is one such item. I will take a look at the 1001 bits plugin for ideas on the UI, and how to make it better.
                                          design.medeek.com
                                            Always cool! 😎
                                            http://s6.postimg.org/5i5h2vsep/charp.jpg
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 75
                                            • 76
                                            • 15 / 76
