    Correctly matching of photos
    11 Posts 3 Posters 6.5k Views 3 Watching
    • omiKronO Offline
      omiKron
      I'm trying to make a model with Photomatch function, but I can't set it up correctly to show only 2 perspective points and a main vertical axe for wall guidelines. Am I doing something wrong?
      • ely862meE Offline
        ely862me
        Yes, everything is wrong.
        You should place the yellow lines on the same wall, top and bottom. And the red lines should start on the opposite/perpendicular wall-top and bottom. This way you get the origin in the corner and there you go..
        Elisei (sketchupper)
        Come and See EliseiDesign
        • HornOxxH Offline
          HornOxx
          Hi Nicholas
          I screenshoted your picture and gave it a try by myself.
          Maybe I'm wrong, but my result is, that your room is not perpendicular
          but a parallelogram. As far as I see it, you did everything correctly but
          the photo match axes can´t work properly where you used them ...
          never trust a skinny cook
          • ely862meE Offline
            ely862me
            Most likely the ceiling is angled.
            • HornOxxH Offline
              HornOxx
              ...also possible!
              This photo is really nasty 😉
              • omiKronO Offline
                omiKron
                The only yellow line I have is the horizon line. I'm aiming to solving this vertical aspect of the image. At this moment it looks like this:
                You can give it a shot if you want.
                • ely862meE Offline
                  ely862me
                  I meant the guiding lines.
                  There is something wrong with the picture.. I even tried to put the guides on the square hanging watch with no luck.
                  http://www.szbda.cn/index.php?m=company%26amp;c=case_view%26amp;a=view_gzcase%26amp;id=150
                  • HornOxxH Offline
                    HornOxx
                    I have found the solution to the problem.
                    Elisei wrote "...There is something wrong with the picture..." - he is right!
                    Yes, the picture itself is the problem! It is a two point perspective, so no "real" 3-point-perspective. The foto had been trimmed artificially into a 2-point-perspective. SkUp-PhotoMatch can´t handle this. PhotoMatch requires 3 vanishing points.
                    I changed the image back into a 3-point-perspective within Photoshop and tried it again - it worked fine! The degree of distortion is not essential - essential is, that there are 3 vanishing points.
                    I attach a screenshot and the dummy SketchUp file...
                    PS:
                    If you're interested, here is a "photomatching" ;- )) link to the website of GMP Architects:
                    http://www.gmp-architekten.de/aktuell.html
                    screenshot
                    Test_PhotoMatch.skp
                    • ely862meE Offline
                      ely862me
                      Actually that photo is a 3d rendering, and the perspective is a 2 point one to get the maximum space rendered. I believe the photo I uploaded is the real deal.
                      • omiKronO Offline
                        omiKron
                        Thank you guys, you really helped me. Now I understand SU doesn't do 2point perspectives in PhotoMatch. Your model is a perfect start for my detailing.
                        Thanks a lot for your efforts. 👍
                        • HornOxxH Offline
                          HornOxx
                          glad to help - maybe you let us see, what you've done later
                          Regards
