    Update model half
    7 Posts 3 Posters 499 Views 3 Watching
    • G Offline
      gary rizzo
      On youtube I see people modeling where they work on half of the model and the other half up dates automatically. What is the plug in I need to be able to do that ?
      Thanks, Gary
        No plugin required for that at all. It's a fairly basic operation with native tools. Make a component of the half, copy the half and flip the copy along the appropriate direction and place it next to the original.
        • BoxB Offline
          Here's a quick example of what Dave has described.
          I added the hidden edge part to make it look like one piece.
          • G Offline
            gary rizzo
            Thanks Dave & Box.
            • G Offline
              gary rizzo
              Dave - Is there a way to add vertices to your model using native tools?
                I don't understand what you need. You can do whatever you need to do with the component open for editing. You can manually add additional points or you can use a tool such as Artisan or Vertex Tools.
                • BoxB Offline
                  I don't quite follow your question either, but, you can right click on a line and select divide.
