    Area class messing up .volume
    6 Posts 3 Posters 798 Views 3 Watching
    • Al HartA
      Al Hart
      We have a plugin which uses .volume on entities but for one user is returning a value of the class Area rather than a number.
      Is anyone aware of a plugin which defines Area or which overrides Entity.volume?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • Al HartA
        Al Hart
        Does anyone know how to determine which .rb file defined a class, or a good way to search all .rb files in Plugins folder, or in all of windows to see which ones contain 'Class Area' or 'Area' (starting with a capital letter)?
        Then I could narrow things down.
        Al Hart
        • TIGT
          If it's in an RBS we're screwed, but assuming it's in an RB I would use BareGrep*** - to search the Plugins folder and subfolders for file type *.rb files and a string - say " class Area"
          *** http://www.baremetalsoft.com/baregrep/
          Baregrep is very useful tool for finding matching text strings in all file types with a folder and nested subfolders...
          • Al HartA
            Al Hart
            By disabling extensions one at a time, it looks like the problem is caused by DesignPH.
            Almost all the rubies ae .RBS
            I'll contact them and see if they can help.
            Al Hart
            • Dan RathbunD
              Dan Rathbun
              ThomThom has an experimental script that defines Area and Volume classes.
              It is on his GitHub site.
              https://github.com/thomthom/SketchUp-Units-and-Locale-Helper
              I'm not here much anymore.
              • Al HartA
                Al Hart
                It turns out the the other developer had defined a override to Length which returned a value of class Area when 2 lengths were multiplied.
                We were multiplying the bounding box extrema to try to calculate an approximate volume if volume was not defined.
                if (entity.respond_to?(:volume)) rval = entity.volume else rval = bwidth * bdepth * bheight end#if
                They plan to fix it, but I think I can coerce each "length" to a float before multiplying them:
                if (entity.respond_to?(:volume)) rval = entity.volume else rval = bwidth.to_f * bdepthto_f * bheightto_f end#if
                Actually I will do this earlier when I get width from the bounding box
                Al Hart
