    Selecting Groups by Name
    5 Posts 2 Posters 467 Views 2 Watching
      jamesn320
      Is there an easy way to select all groups that have the same name?
      I have imported a large model from Tekla, it has not created separate layers but it has grouped each assembly. One group for each column etc. I want to texture all the steel, concrete, asphalt etc differently but this would be a very time consuming processes unless I can easily select all groups with the same name. Unless there is another way?
      http://i893.photobucket.com/albums/ac133/jamesn320/Object Name_zpsqufmahbn.jpg
      Cheers,
      James
      • sdmitchS Offline
        sdmitch
        Cheers,
        James
        Your example is a component instance so I assume that is what is to be selected rather than groups.
        The following code can be pasted into the Ruby Console and executed to select Component instances by name
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        cin = ent.grep(Sketchup;;ComponentInstance).map{|ci|ci.name}.uniq.sort
        ipb = UI.inputbox(["Name to Select;"],[cin[0]],[cin.join("|")],"Select by Name")
        if ipb
          sel.clear
          ent.grep(Sketchup;;ComponentInstance).each{|ci|
            sel.add ci if ci.name==ipb[0]
        http://sdmitch.blogspot.com/
          jamesn320
          Wow! Thanks. That is exactly what I wanted. I have never used the Ruby Console before. Your code even adds the different groups names to the drop down menu.
          Thank you very much!
          James
            jamesn320
            I feel like I am about to go on a steep learning curve, is it possible to add that script into a button on the tool bar?
            Cheers,
            James
              jamesn320
              I've got it to now be on the drop down menu, Happy days. πŸ˜„
