    Applying "fish scales" to an irregular surface
    15 Posts 5 Posters 1.2k Views 5 Watching
    • W Offline
      wheelz
      I have a task that very well may be impossible. I am trying to apply overlapping vinyl records (e.g. fish scales or roof shingles) to an irregular shaped surface. I can create the surface a number of different ways.. with curviloft, ffd, extrude by rails... but the real challenge has been applying the records. I have tried using combo spray and make fur plugins but have not been able to configure them to achieve the desired results.
      I have attached an example of what I'm trying to create. Any input will be appreciated.
      • cottyC Offline
        cotty
        A quick example with ThrowTo, maybe a starting point?
        my SketchUp gallery
          driven
          did you make the record a 'glue to + any' component?
          • cottyC Offline
            cotty
            No, and I think that won't work in this case.
            my SketchUp gallery
              driven
              did in my quick test...
              john
              • cottyC Offline
                cotty
                Nice, which steps are you using for this result?
                my SketchUp gallery
                  driven
                  I just applied the bottom row manually, selected the row, then Move copy 12x...
                  I then tilted [Rotated] the component geometry 2º on 2 axis to overlap each other...
                  johnyou have to drag them from the Component Browser...
                  • W Offline
                    wheelz
                    Nice!
                    I think that will do it.
                    Now to add another layer of complexity... can you think of a way to have all of the circles rotate in 2 axis relative to the plane that they are attaching to?
                    • KrisidiousK Offline
                      Krisidious
                      Japanese Roof Tile Fish End Cap.skp
                      By: Kristoff Rand
                        driven
                        that's basically what happens when you adjust the internal geometry...add guide for easier selecting...
                        you could start with a more obvious input point and erase it at the end...
                        john
                        • W Offline
                          wheelz
                          I get that, but it falls apart when the irregular surface starts curving in both directions, as is the case with the project that I'm working on.
                          example
                            driven
                            copy paste your wall into a new skp and color the target faces a distinct color and I'll see if some ruby code can add them in place...
                            • pbacotP Offline
                              Wonder if flowify would help. In reality it would distort the scales, but that may not be noticeable.
                              • cottyC Offline
                                cotty
                                Worth a try...
                                flowify_fish.zip
                                my SketchUp gallery
                                • W Offline
                                  wheelz
                                  really appreciate the help.
                                  file is attached
                                  recordWall
